First post, by SteFam
Hi,
I am facing a stange problem, I wanted to replace the VGA in my 386 DX 40 by an ET4000 (isa 16, 1MB).
When I install the ET 4000 the computer stops after the bios checks.
I played around with some different Controller cards, best option is that only the FDC is not working.
I checked this also on two different 386 DX 40 boards with the same result.
I even checked with two different ET4000 Cards the same problem.
My option on that is that there is an address conflict. Unfortunatly the controllers have no ability to change the adresses.
On the Graphic Card I don't see any option/jumper to switch adresses.
Anybody :
* have an idea how to find and solve that problem
* knows good programms for analyses (beside checkit and nssi)
* some general ideas ... it is really strange
* A controller that can use different addresses or works with ET4000
Thanks for your help in advance, if you need further information let me know, then I will enhance this post 😉
BR Stefan
By the way I have searched before I wrote this, but maybe you have better a better search string for me.
searched for differnet combinations of ET4000, Address, conflict,FDC , Problem, (80)386 ...
Reply 1 of 10, by BloodyCactus
the ET4000 does not have any IO ports on the Floppy/HD IO range. all these cards used fixed addresses that dont overlap.
what was your original vga card?
--/\-[ Stu : Bloody Cactus :: [ https://bloodycactus.com :: http://krÄketÊr.com ]-/\--
Reply 2 of 10, by SteFam
@BloodyCactus thats the same I thought, I don't understand this.
Original card was a
Cirrus Logic GD5424 1Mb
Whole system is a Escom Slim Line
Original Mainboard was
FIC 386-SC-HG Rev:A
(I had some trouble to install 16MB ram (adressline seems not to be connected or one of the bus tranceiver has a defect)
Currently I use a
VIA-4386-VC-HD
Checked also some Bios versions before I switched the boards, currently I have a 486 Bios on the FIC 386-SC-HG Rev:A.
I have still the opinion that it must be something differnent, but when I remove the original hdc pc boots, if I install a different than the orginal Winbond Multi IO Controller, I can at least boot but FDC is not working.
Reply 3 of 10, by BloodyCactus
only thing I can think off is, some cards output a vga irq, most do not. its not a common used irq (its like irq 2/9?) and sometimes thats reserved by ACPI.
Reply 4 of 10, by SteFam
Thanks for the hint, now I have something addtional to be checked. I will check and come back.
I tested the graphics cards in the meantime in an 486 (without the io card, board has IDE and Floppy on board) There both HDC and FDC worked with all of three ET4000's.
Reply 5 of 10, by SteFam
Hi sorry for the late reply, I had different things to do. All trys in that direction did not lead to a solution. I read something that the IRQ might not be correct disconnected and you need to isolate it. Thats what I havent not tried until now. Does anybody have another idea. I have put back the Cirrus Logic GD5424, with that card everything works fine. Maybe it is something wrong with that old ET4000 Cards, a general error, a defect pullup, capacitors that gone bad. Visual inspection showed no result and the cards work fine in 486 and if I switch off the fdc.
Have a good week
Reply 6 of 10, by mkarcher
I don't think this is an IRQ conflict (graphics cards are only connected to IRQ2/9, and I/O boards in default configuration are not connected to that line). Furthermore, I also don't think it is a port conflict, because the ET4000 card does not use any ports outside of the 3B0-3DF range reserved for ISA graphics cards. As you tried multiple ET4000 cards, I also don't think the issue is a marginal card.
My current hypothesis how this might happen is an incompatiblity between your mainboard BIOS and the Tseng video BIOS. For example, the Tseng BIOS might require more stack space during the POST than the mainboard BIOS provides, and cause data corruption due to an undetected stack overflow.
Reply 7 of 10, by SteFam
Hi mkarcher,
thanks for this additional view and informtion. I agree I have never heard of such conflicts with a wide used graphic card. I saw some posts where IRQ2/9 was used because of wrong/broken pulldown/up. But those things seems to be very unlikely when I check this with several different isa card combination. I also checked it with three differen Mainboards FIC 386-SC-HG Rev:A (AMI Bios), VIA-4386-VC-HD (Award) and a 486. The 486 worked therefore I installed a chipset compatible 486 Bios on the 386 (not only one a bunch of with some tests) but without a better result. I have currently installed back the old graphics card (Cirrus Logic GD5424 1Mb).
Is there a possibility to check/test this assumption with the stack? I mean I will test some additional different bioses and maybe I should test it also with a 286 if that works. I still think that I make a really stupid mistake 😉
BR Stefan
Reply 8 of 10, by mkarcher
So you tested with different 386 boards, also using different BIOSes, which makes the "your oddball BIOS is incompatible with the Tseng video BIOS" theory unlikely as well. But did you use different 386DX-40 processors? If you used the same CPU in both boards, possibly that CPU is bad, and the Tseng BIOS triggers misbehaviour of the CPU. Also you might want to try a lower clock speed.
Reply 9 of 10, by konc
What about ISA timing? Is it standard and slow enough during your tests?
Reply 10 of 10, by SteFam
Hi Sorry again for my late reply.
I think also the bios/board combination is incompatible with Tseng, I have tested it with two mainboards but they have different manufaturer Ami and Award. Maybe they are very similar. Yes I tested also other Bios versions even early 486 for a similar chipset.
About Isa timing, I checked ratio and ws in differen configurations.
One day I had a 286 on my table and the gotec was not working. I had already had an XTIDE in a slot and added then a floppy bios. Surprise it worked very well, after some Addressconflicts.
Therefore I thougt how would it be to have both on the same ROM this also worked (no in-system update possible) . After that I wanted to try the rom in my 386. This took until today. Long story short after adding this bios and not using the original bios for IDE and FDC worked with another ET4000, which I was currently working on. But I need to test it with the earlier used ones, too.
I will report here, sorry can take a while ...
BR Stef
