First post, by pixecs
Hi all,
I acquired a Totem TM-586TX4 motherboard from flea market, but some components are missing from the CPU power supply circuit (they were de-soldered).
The board seems to be in a good condition, except for the missing ATX connector (it still have the AT connector in place) and the BIOS chip.
The missing components from the power supply circuit are: D11, Q7, Q8 and CT8.
I checked the thread Socket 7 motherboard condition? Totem TM-586 TX4 and D11 appear to be S16C40C, Q8 is TIP168 but Q7 is not very legible. I also assume that CT8 is a 1500uF/6.3V capacitor.
Can anyone help me figure out what type Q7 is?
Thank you.
Reply 1 of 3, by pixecs
Also the board is version 2.1 but the CPU power delivery circuit appear to be exactly the same as the one from mentioned thread.
Reply 2 of 3, by pixecs
I resurrected the motherboard using a KT818G for Q8 and a KT819G for Q7 that I had in my spare box.
For D11 I put an SBL2040CT and for CT8 a 1500uF/6.3V capacitor.
For the BIOS I wrote an AM27C010 with the BIOS file from The Retro Web.
Everything seems to work fine except that Q7 and Q8 are getting too hot on a Pentium 133MHz.
So I guess I'll need another pair of transistors with a larger Ic.
Reply 3 of 3, by pixecs
I finally had time to check the power supply circuit of this board.
Since I didn't have any original components, I used a pair of D44VH10 (NPN)/D45VH10 (PNP) for Q7/Q8.
The pair was getting very hot during testing with a Pentium 200 MMX, so I moved D11/Q7/Q8 to a heatsink mounted on top of the PCB using 3 screws and the existing holes for the relocated components.
I also had to cut the trace between pin 9 of the TL494 and Q10, because after a short period of time the IC became too hot to touch, so I put a 68 ohm resistor.
The PWM output was a bit too "hairy", so I put ferrite beads on pin 2 of D11 and on the B&E terminals of Q7, and also put a 470 ohm resistor between the B&E terminals of Q7.
Testing, using a DOS fractal generator, with a Pentium 200MMX, the heatsink temperature stabilized around 75 degrees Celsius, and with a Pentium 166 (non-MMX) it stabilized around 50 degrees.
