First post, by eddman
Till a few months ago it was possible to download driver files. You just had to click on the listed file name instead of the large buttons. Now it doesn't work anymore and simply downloads the outbyte garbage software.
Anyone know a workaround or are the files gone now?
Reply 2 of 17, by eddman
I just installed outbyte in a VM but don't see any option to search for driver files. It only has an scan option, and even that says no connection for some reason.
Reply 4 of 17, by SA1988
I was trying to download es142_1.exe and es142_2.exe from driverguide but driversdownload from solvusoft said access denied for these packages, for the first, the id is 366130.
Reply 5 of 17, by vetz
SA1988 wrote on 2026-02-05, 20:27:
Its not a perfect alternative. Solvusoft does not have all the files.
Reply 6 of 17, by SA1988
Then I guess Corel SCSI 2.1 Panasonic OEM is lost.
Reply 8 of 17, by SA1988
Well, it doesn't come with a proper installer for DOS.
Reply 10 of 17, by keenmaster486
Sites like that only exist to scam Grandma into installing malware. They couldn't care less if you can actually download drivers or not.
World's foremost 486 enjoyer.
Reply 11 of 17, by eddman
vetz wrote on 2026-02-06, 18:58:
Is it just me, or has the filename download now been removed?
Uuu... yea... that's what I mentioned in the OP.
Reply 12 of 17, by vetz
eddman wrote on 2026-02-06, 20:33:
No, the clickable link is gone. When you posted it earlier it was still there, but it linked to their software instead of the file.
Reply 13 of 17, by BitWrangler
try looking for them on majorgeeks or softonic
Reply 14 of 17, by SA1988
majorgeeks doesn't have them, neither does softonic.
Reply 16 of 17, by wierd_w
I also was able to get a few over the weekend.
Reply 17 of 17, by eddman
vetz wrote on 2026-03-30, 15:01:
Looks to me that downloads are back.
That's very good. Everyone here should back up any file that can't be found in other places. I'm not sure how much DriverGuide can be trusted going forward.
