First post, by yevrowl
About to put together another logic game with colored blocks for Composite CGA.
Please advise how to assign 16 (at least 8) colors.
P. S. Is it possible to also call up the 160 × 100 (200) × 16 color mode?
Reply 1 of 2, by wierd_w
You can control the CGA card with io port prodding, using the OUT command.
QB is just much slower at this, so fancy things (mid-scanline operations, et al) would still need assembler. Iirc, you CAN inject assembler into a QB function, but I dont remember how.
Found it.
http://petesqbsite.com/sections/tutorials/tut … _appendix1.html
So, if you want to do the fancy CGA craziness, fast enough to actually do it, you can make and use assembler functions to do it.
Reply 2 of 2, by wierd_w
Traditional NTSC composite/artifact color, works by halving the effective horizontal resolution, and abusing the fact that certain single pixels next to each other 'bleed' to create a new effective color.
This is how, eg, maniac mansion does stuff.
Fancy artifact color interrupts the scanline mid-render, which changes the effective signal the crt interprets as the scanline is generated.
This second method is how you get 1k colors in demos, like the 8088mph demo.
https://youtu.be/YwU3dc96Ot4?si=jMVASZO4oi7uYA7t
(Technical writeups for 1k color mode)
https://www.reenigne.org/blog/1k-colours-on-c … a-how-its-done/
https://int10h.org/blog/2015/04/cga-in-1024-c … de-illustrated/
