First post, by Omarkoman
I have this great board with a Pentium Pro 200 I want to create a new build and put in a larger SSD drive in (eg 64GB)
https://theretroweb.com/motherboards/s/gigabyte-ga-686fx
Trying various mechanical drives of sizes around 40GB etc and SSDs, it does not detect them at all, it actually freezes in the BIOS HDD detection screen. Smaller drives work.
I searched Wims but couldnt find anything there. Is this boards BIOS even patch-able? Or should I just use a PCI IDE/SATA card ?
Reply 1 of 13, by wierd_w
XT-IDE on a NIC?
Reply 2 of 13, by Omarkoman
Yeah I have few of those but they slow down the drive significantly, also they cause issues with optical drives. I can try to have a play but wanted to see if there was a cleaner eg bios patch option as i did that on quite few of my other boards and works perfectly.
Reply 3 of 13, by NeoG_
Unless you can get the attention of someone familar with patching BIOS files for drive support, a PCI card is going to be the next best option. You can leave your ATAPI devices connected to the mainboard for boot support and just put the drive(s) on the PCI card. Most PCI cards won't boot from ATAPI IDE devices.
Reply 4 of 13, by Omarkoman
Fair call, thats actually what I am planning to do now experimenting with win98 install .
How can i get the installer to see the drive on the pci controller?
https://i.postimg.cc/DFyvtz6p/IMG-1976.jpg
The ssd is detected but the os doesnt recognise itZ i even tried the speed win98 installer which i think uses linux?
This one : https://github.com/oerg866/win98-quickinstall
It doesnt see the drive/controller.
Reply 5 of 13, by NeoG_
Which controller card are you using
Reply 6 of 13, by wbahnassi
Shrinking the drive with SeaTools might work... unless you really want its full capacity. But at least you can use newer quieter drives even if most of their space is wasted.
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 7 of 13, by Chkcpu
Hi Omarkoman,
I’m familiar with patching Award v4.5x BIOSes for better drive support.
The latest (and only) GA-686FX BIOS I see on TRW is the V1.4 (06/29/1998-i440FX-8669-2A69HG09C-00).
Is this the BIOS version you are running, or do you have a newer BIOS?
If not, the V1.4 BIOS has indeed the infamous Award BIOS 32GB IDE HDD limit bug. I can patch this bug for full 128GiB/137GB HDD/SSD support.
Let me know which BIOS version you have, so I can patch the most recent one.
Cheers, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 8 of 13, by Omarkoman
Chkcpu wrote on 2026-02-05, 12:35:
Hi Omarkoman, […]
Hi Omarkoman,
Cheers, Jan
hi Jan
yes that is the BIOS I am running, the V1.40 from retroweb. Would be amazing if you can patch it !!!!
Thank you !
Reply 9 of 13, by Chkcpu
Omarkoman wrote on 2026-02-06, 20:42:
hi Jan […]
Hi Omarkoman, […]
Hi Omarkoman,
Cheers, Jan
hi Jan
Thank you !
I’ve patched the GA-686FX V1.4 BIOS for full 128GiB/137GB IDE drives support and Omarkoman has successfully tested this BIOS on his board.
This “patch J.1” BIOS is now available on TheRetroWeb at https://theretroweb.com/motherboards/s/gigabyte-ga-686fx for all GA-686FX users.
Cheers, Jan
Reply 10 of 13, by nuno14272
Why not use ontrack disk overlay.? super easy.
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 11 of 13, by wierd_w
Because native 48bit support is way better, and does not burn conventional memory?
Reply 12 of 13, by NeoG_
wierd_w wrote on 2026-03-10, 18:56:
Or in this case, native 28-bit support
Reply 13 of 13, by Omarkoman
Jan is a top guy! The patch worked perfectly.
And yes, much better to have native support than faff around with software solutions!
