First post, by YesAffinity
I had my Pentium II rig dual booting DOS and Win98 with no issues. It would boot to DOS, and if I need to get into Windows for something, I would change directory to the Windows directory and type Win to reboot into Windows. I would then restart into DOS mode from within Windows.
I then hadn't touched the machine for a few months, booted into Windows and then rebooted into DOS mode, and now cannot get back into Windows. Don't know what I did, hoping it's an easy fix.
Currently, I boot up the computer and it goes to the Windows 98 startup menu.
If I choose Normal boot there, it takes me into DOS startup selection.
Once in dos, I cd to windows directory, type 'win', choose 'y' to return to normal mode, and the PC reboots to the above.
I've poked around in msdos.sys, autoexec.bat and config.sys, not seeing anything glaring that is out of sorts. But again it's been quite a few months since I dialed this system in and I've already forgotten a lot of the finer details of what I had learned and what I did to get it dialed in.
Seems something is buggered with booting into Windows, but I can't figure out what it is. All help appreciated.
