First post, by Bill123BB
When I first started using DosBox and switched to full screen, my Samsung 192N LCD monitor would be black except for moving block that said Video Mode Not Supported. Remembering a similar problem when I first got the monitor, I checked monitor properties in my Radeo 9600 card and found that EDID was reporting the monitor could run at 84Hz and changing to that when in 640x480 full screen. The monitor can only a support a max of 60Hz. When I set the card not to us EDID and manually set the max refresh rate to 60Hz, it worked fine in full screen
