First post, by middlenibble
Hi all,
I'm trying to configure a MartyPC box which performs like an 8088 at 8 MHz but can't make it work. It's either 4.77 MHz or something above that via the turbo button. I appreciate any insight.
Hi all,
Turbo should be 7.3MHz. In what way are you seeing it way above that?
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
I'm using the ibm5160_xtide config.
Without turbo, Topbench scores 4 and classifies the box as an Intel 8088 @ 4.77 MHz.
With turbo, the box scores 13 as an NEC V3 @ 8MHz.
middlenibble wrote on Yesterday, 14:18:I'm using the ibm5160_xtide config.
That's not incredibly far off the mark, although I'm not sure why it's picking up an NEC for that. Do we have results to compare to from a real 8MHz system?
FWIW turbo is upwards of 14 MHz for me.
World's foremost 486 enjoyer.
keenmaster486 wrote on Yesterday, 18:08:FWIW turbo is upwards of 14 MHz for me.
It really shouldn't be. Can you take a screenshot of your performance window with turbo on?
