First post, by vbug
Hi, I own a Toshiba T1960cs, it works well, but the screen colors are dull/tern/whitish, especially when the screen is turned on for some time/warm, the black is whitish, even after adjusting the brightness wheel on the side of the screen. I own several T1900cs series but the others have brighter colors. I replaced all little 50v 10uf capacitors inside the screen (on the lcd driver only, I didn't touched the inverter), but it didn't changed much. I'm wondering if there is some capacitors on the motherboards I should replace as well to get the screen working properly. Any advice welcome. Thanks.
