First post, by chubabs
Hello, I need help modifying an adapter to work on a dual slot card. Could you please advise me on what can be done.
Motherboard - Soyo SY-D6IBA Rev 2.0
https://theretroweb.com/motherboards/s/soyo-sy-d6iba-rev-2-0
A mod was made for FCPGA2 processors to work, and both adapters work perfectly, also post individually in single mode on this board, but when paired, they either do not post at all or hang on C0 or C1, which indicates that the issue is clearly with the SMP mode. I also observed that some adapters require a 1kOhm resistor, but this did not change anything.
The motherboard is 100% functional and works perfectly with two factory slot 1 processors.
Perhaps someone has experience using this adapter in dual mode.
