First post, by *skyvlan
Hi, i have a jetway j-402b with an Intel Overdrive 486DX2-66 that was working just fine previously,
But suddenly it stopped working, turns out there's a tantalum capacitor damage near the AT power pins
(C8)
I got the battery replaced already but due to logistical errors both the battery holder and tantalum caps received mechanical damage to it
Does anyone know what exact components are needed to replace the two sheared capacitors?
The system had previously been booted with this condition and failed to POST, but removing the ram makes that no ram alert
Is there a chance that i might've killed the CPU?
Here's the images attached:
Reply 1 of 2, by majestyk
10µF, 25V will fit perfectly.
Don´t worry about the CPU.
Reply 2 of 2, by *skyvlan
majestyk wrote on 2026-03-02, 08:31:
Thanks, i was worried i might've fried the CPU
