First post, by DustyShinigami
One thing that's puzzled me for a while now are the brackets for my CPU. These brackets were on the motherboard when I bought it, along with the Pentium III, and I'm not sure if I'm misunderstanding how they're supposed to work, if they're broken, or just the wrong type. I can't seem to figure it out and the CPU just isn't being locked in place. Both ends fold inwards when there's no CPU, but bending them inwards when it's installed, doesn't snap/lock into place. Both have a sliding holder, too. But again, whether it's up or down, it doesn't seem to lock anything in place.
https://streamable.com/5i6sot?src=player-page-share
https://streamable.com/mpncyt
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 6, by wierd_w
Those are part of the Slot1 retention system.
When an actual Intel Slot1 processor module is inserted, the clips snap into the sides of the module, and it wont come out until you play silly games with the clips.
The clips only fit the Intel slot1 packages, not slotket adapters.
https://imgur.com/HMw3dBT
Reply 2 of 6, by Beerfloat
Probably just the wrong type. These brackets could be easily replaced with 2 screws each attaching them to the board.
There are universal brackets that can stay snug on all variations of the SECC1/2 cartridges and the bare PCB CPU modules with heatsink with wings types (tho not the myriad of slotkets).
Most included brackets were not the universal type.
It's not a big deal unless you regularly transport your computer upside down. The force of the slot1 cartridge connector itself is generally pretty good.
Reply 3 of 6, by DustyShinigami
wierd_w wrote on 2026-03-03, 16:53:
Those are part of the Slot1 retention system. […]
Yeah, I watched a video showing those two clips at the sides, but mine doesn't have those. So, are the CPUs I have not actual Slot 1 processors...? But slotkets? I was under the impression they were Slot 1. Or is it some sort of hybrid?
OS: Windows 98 SE
Reply 4 of 6, by DustyShinigami
Beerfloat wrote on 2026-03-03, 16:58:
Probably just the wrong type. These brackets could be easily replaced with 2 screws each attaching them to the board. There are […]
It does make it easier to switch between my PIII and PII, but it would just be nice to understand why they never lock. And maybe get something more suitable.
OS: Windows 98 SE
Reply 5 of 6, by Shponglefan
DustyShinigami wrote on 2026-03-03, 17:05:
Slot 1 is the slot specification used by Pentium II and certain Pentium III and Celeron processors. The processors encased in the black plastic case is known as SECC (Single Edge Contact Cartridge).
Celeron processors typically used the SEPP (Single Edge Processor Package) which lacks the black plastic case. But they are still slot 1 processors.
Slotkeys are converters that allow a socketed processor (typically Socket 370) to convert to a Slot 1.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 6 of 6, by DustyShinigami
Shponglefan wrote on 2026-03-03, 17:43:
Slot 1 is the slot specification used by Pentium II and certain Pentium III and Celeron processors. The processors encased in t […]
I see. So what I have are Slot 1s. I just don't have the right brackets.
OS: Windows 98 SE
