First post, by douglar
- l33t
I recently bought a quadro4 900 xgl, essentially a 4600ti, that was in worse shape than I thought.
https://theretroweb.com/expansioncards/s/nvid … quadro4-900-xgl
I knew that the puffy 470uf caps on the front likely need replaced, but there are a number of SMD components on the back that appear to be missing that surprised me--
Even if I fix it up, what are the odds that the GPU is burned out? Is it safe applying power to find out?
Here are some links to similar cards--
https://theretroweb.com/expansioncard/image/g … 4d474082282.jpg
https://theretroweb.com/expansioncard/image/b … 6e992203630.jpg
https://theretroweb.com/expansioncard/image/i … ec622780488.jpg
Any help guessing what parts to use would be appreciated. I could probably pull many of these from my rack of donor win modems.
