First post, by fyredragon69
Hello all! Yesterday I acquired two machines; a Pentium MMX, and a 486. I checked and ensured both worked before I left, and I currently have Windows 98 SE running on the Pentium MMX machine, so far it's been wonderful. My only issue is.. I don't have any blank CDs or floppy disks to get files to and from the machines. It seems like the Pentium machine has an ethernet card installed, which makes things a bit easier but I'd prefer something easier, like a USB card or perhaps a floppy emulator. Are there any recommendations for either options? If so please leave a link to them below, it would be much appreciated.
Reply 1 of 11, by DaveDDS
Check out my DDLINK
Single small .COM file, doesn't have to be installed or need any other components (other than a "packet driver" for netaork). Can transfer individual files or whole directory tree, has a fairly decent (IMHO) visual interface.
Can transfer over Netowrk, Serial or Parrallel connections.
Available free on my site.
DDLINK: Easily move files between/To/From DOS systems
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 2 of 11, by Shponglefan
My recommendation would be to look into a compact flash adapter. It can allow you to use a compact flash card like a removable hard drive. I use them a lot of my systems ranging from XT to Pentiums.
This is the adapter I use: https://www.amazon.com/Syba-Connects-3-5-Inch … R/dp/B001JTO782
You do have to be particular about which compact flash cards you use. I recommend either genuine Sandisk or Verbatim brand card.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 3 of 11, by DaveDDS
fyredragon69 wrote on 2026-03-04, 13:14:
... or perhaps a floppy emulator ...
Check out GoTek floppy emulator. Completely emulates a 3.5" floppy (connects t0 the floppy cable) and can emulate multiple floppy images on a single USB "stick".
Reply 4 of 11, by fyredragon69
DaveDDS wrote on 2026-03-04, 13:44:
I was considering getting a GoTek, wasn't sure which model though. I really don't care for the OLED display and rotary encoder on the newer model, so I'd probably go with a cheaper one. Any recommendations for that or do they all work the same? I recall some years ago there were two models, one for 720k and one for 1.44mb disks.
Reply 5 of 11, by fyredragon69
Shponglefan wrote on 2026-03-04, 13:43:
Completely forgot about compact flash adapters heh, will definitely look into that. Thanks!
Reply 6 of 11, by Disruptor
fyredragon69 wrote on 2026-03-04, 13:48:
Oh, the rotary and display are so useful !
Reply 7 of 11, by fyredragon69
Disruptor wrote on 2026-03-04, 13:53:
I'm sure it would be, but it costs as much as two normal GoTek's. I'd much rather get two to put in both systems, than swap the one between the two. I don't wanna dump too much money into this.
Reply 8 of 11, by Shponglefan
In my experience Gotek emulators are good for disk images if you need to install programs from floppy disks. For file transfers though you'd be limited by the size of conventional floppy disks.
Reply 9 of 11, by RetroPCCupboard
As you have win98SE, and haven't disabled USB ports, I'd just buy a cheap USB stick. Maybe 8gb, and install a USB mass storage driver on the OS.
Reply 10 of 11, by MikeSG
You can get USB on both PCI and ISA cards
Reply 11 of 11, by DaveDDS
I don't have in front of me .. I got a basic GoTek .. no rotary, simple display .. does 1.44 & I think 720 - works well & does what I wanted
Search on here .. there's a couple threads about it
