Tatung Einstein
First post, by yevrowl
The attachment Tatung-Einstein.png is no longer available
https://en.wikipedia.org/wiki/Tatung_Einstein
Reply 1 of 5, by yevrowl
The attachment scr-1.png is no longer available
The attachment scr-2.png is no longer available
The attachment scr-3.png is no longer available
The attachment scr-5.png is no longer available
This computer game is based on BrainTeaser by Wim Nijland.
Choose digits from 1 to 9, split by reaction method into three groups: 1-3-7-9, 2-4-6-8, and 5.
The goal is to display all digits except 5, avoiding the field clearing.
The source code in Xtal Basic is attached —
The attachment bt-src.7z is no longer available
Reply 2 of 5, by yevrowl
Using EDIP, write the source code to a floppy disk and load it through the MAME emulator.
It works in Xtal Basic 4.2 and 5.0.
The attachment compile.png is no longer available
However, cannot save it with the SAVE command in any form due to a “Bad Data” error, and have the same problem with compilation.
What could be the reason?
A boot disk containing the compiler and source code is attached.
Reply 3 of 5, by yevrowl
Compiled it using a CP/M-compatible operating system on MSX. The result, which requires the runtime (xr.com from the compiler package), is attached below.
Reply 4 of 5, by yevrowl
Implementation of the logic game «Master Mind».
The source code and the compiled file are attached.
Reply 5 of 5, by yevrowl
The color palette on the Einstein-256 seems to be better:
The attachment einst256.png is no longer available
This model offers a total of 512 color shades.
