First post, by HomeLate
I'm trying to reset the system password on an Olivetti M380/XP9 with a BA832 motherboard (BIOS Rev 1.07).
Here's what I've tried so far:
- Removed the CMOS battery and left it out for an extended period — no effect. The password prompt persists.
- Tried common default passwords (OLIVETTI, blank, etc.) — none worked.
- Located and removed the PAL chip at U104 (identified as PWPRO — password protection — in the Olivetti service documentation) — the system would not boot without it, so this isn't viable.
- I have the original Olivetti Setup Utility diskette, but the password prompt appears before the system will boot from floppy, so I can't use it.
From the Olivetti service manual I can see the BA832 uses an 82C206 integrated peripherals controller, and the Extended Setup references both CMOS RAM (64 bytes) and a separate NV RAM area. The password appears to live in NV RAM.
What I'm looking for:
- Any information on the specific NV RAM chip used on the BA832 board and how to clear or replace it
- Whether anyone has experience with the 82C206 and knows of a hardware method to reset its NV RAM
- Whether it's possible to reset the password
Any help would be greatly appreciated!
Reply 1 of 2, by weedeewee
Interesting...
https://theretroweb.com/motherboards/s/olivet … p9-ba832,-ba839
no photo or bios available.
Any chance you could provide those ?
Clear photos can be used to find any possible nvram chip that might contain a password
Bios files might be altered to bypass any password prompt.
Do not ask Why !
Reply 2 of 2, by HomeLate
I'll submit some photos soon on the Retroweb. I'll also upload an image of both 27256 chips.
Here's a picture of the mainboard. I'll make a better picture soon for the Retroweb:
The attachment image-1773419600765.jpg is no longer available
This is the password prompt I'm seeing, halting the system to continue booting:
[attachment=-1]PXL_20260312_180202918.jpg[/attachment]
