First post, by subhuman@xgtx
Hiya all long time no posting here.
The 2003-2004 era gaming bug recently bite me and during the last couple of days I put together a Biostar P4M266 board, along with 2x512 sticks, a 2.8 ghz Pentium 4 with 533 fsb and a FireGL X3 256 modded to 16 pipelines (560/530) with retail Radeon drivers (Catalyst 6.2), all running under Win XP SP3. The card is set to AGP 4X (the max supported by the chipset) with FW on, with an aperture size of 256mb.
I managed to get the retail 2004 version of Half-Life 2 working on this system. However, to my dismay, the framerate at 1024x768 no AA is simply abysmal, dropping from 130+ fps in indoor areas to 30-40 fps during the first sections of the railway underpass/tunnel.
Is the retail version of the game known to perform shittastically? Or is it this VIA chipset is just lacking too much in terms of memory bandwith and AGP performance? I find it quite curious how 3DMark03 gives me a score of 110xx, which is probably a sign of a CPU bottleneck but nonetheless a good enough score to run this game fluently.
Cheers!
Bear in mind I usually post to the forums using my old systems.
Reply 1 of 13, by Shagittarius
Use opengl renderer if you are not.
Ignore this, For some reason I thought he was talking about the original half-life, i missed it.
Reply 2 of 13, by leileilol
There's no OpenGL renderer in launch HL2. That was added later on when they added Mac support.
I remember most of my HL2 launch performance problems to be i/o / swap related with it not really caching in sounds well. There was also a fandom that denied HL2 having problems then putting the blame on a bad pirated version (i had hl2 on my steam since '04, so).
When I did go back to complete HL2 on a Radeon x850, it was a pre-orange box build with busted fog issues - but didn't have performance problems. Didn't run it on a P4 though
long live PCem
Reply 3 of 13, by subhuman@xgtx
The slowdown is such that everything will load really fast (I'm using a small 120gig SSD with an IDE to SATA bridge at UDMA5).
However, open scenes which are even the slightiest bit more demanding in terms of polycount and physics (i.e wherever I'm looking at that isn't a corridor) make the framerate tank really bad. Win98SE or XP it's really the same. Supposedly, that molex connector is plugged in quite tight.
RAM, although slow for P4 DDR standards thanks to this VIA chipset, should be plenty in terms of size, never going over a total of 650mb ingame.
Reply 4 of 13, by NeoG_
I think you should bench the CPU alone to see if it's performing like it should, the drastic difference in FPS usually points to a CPU limitation
Reply 5 of 13, by NitroX infinity
The cpu is absolutely not the problem. The original 2004 HL2 requires a 1.2GHz cpu minimum. So that 2.8GHz P4 is more than enough. Considering the P4 2.8 (Northwood) came out in August 2002, it absolutely would not be an obsolete cpu at the time of HL2's release.
The problem is either the motherboard, the ide to sata adapter or the FireGL card.
@subhuman@xgtx; do you have anther non-workstation videocard to test with?
Reply 6 of 13, by DrAnthony
Yeah, something is off here. I played through at launch with an Athlon XP (I want to say 2600+) and a Radeon 9800 Pro at that resolution and it was smooth sailing. While my setup likely had a bit an edge on the CPU side, your GPU is MUCH faster. I would have anticipated 100+ fps even with 2x AA enabled. How's the frame pacing? Does it drop to a steady 40 or is it more like 100 fps bursts with choppy freezing?
Reply 7 of 13, by subhuman@xgtx
NitroX infinity wrote on 2026-03-16, 11:46:
I will have an X850 XT AGP coming during the next weeks but the only cards I can test right now are this and then a normal 64mb Geforce3 and a 9000 PRO which wouldn't run this game in directx9 at all.
I tried a Tualatin 1400-s @1750 + Asus Tusl2c setup with the FireGL and the result is pretty much the same, albeit with lower averages, of course.
Reply 8 of 13, by isaacx123
I have similar performance on my X1650 Pro and Athlon XP 3000+, 100-90fps in closed areas and 25 to 40fps in open areas, I am playing the Orange Box edition.
GB GA-7NNXP | AMD Athlon XP 3000+ (400MHz) | SAMSUNG 2*256MB DDR-400 | ATI Radeon 9600 Pro 256MB | Win98SE
WIP GB GA-EP45-UD3P | Intel Pentium 4 HT 651 | G.SKILL 2*2GB DDR2-1066 | AMD Radeon HD 6870 1GB | WinXP SP3
Reply 9 of 13, by ciornyi
Are you sure your cpu running @2.8 Ghz ? Your motherboard supports only 400mhz fsb so you should have 2.1ghz . Also this motherboard is crappy one with VIA PM266 chipset it was packet in white boxes without any brand mention on it as manufactors scared intel's comply .If you want better results just go with intel 845E/848 chipsets.
DOS: 166mmx/16mb/Y719/S3virge
DOS/95: PII333/128mb/AWE64/TNT2M64
Win98: P3 900/256mb/SB live/3dfx V3
Win Me: Athlon 1333/256mb/Audigy2/Geforce 2 GTS
Win XP: E8500/4096mb/SB X-fi/Quadro fx 4500
Reply 10 of 13, by Repo Man11
Comparing my Amptron M930 (SiS 645) to an ECS P4VXASD2+ (Via P4X266) with all else the same, I was surprised at the performance gap between the two. The SiS 645 was significantly better all around; all of these scores were after I tweaked everything I could on both systems to achieve the highest scores I could.
And the Amptron board (combined with a 9800 SE with the pipelines unlocked) wouldn't have been a machine that I would want to try HL-2 on; I did find it satisfactory for Half-Life, Opposing Force, and Blue Shift.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 11 of 13, by ciornyi
Repo Man11 wrote on 2026-03-16, 18:50:
Comparing my Amptron M930 (SiS 645) to an ECS P4VXASD2+ (Via P4X333) with all else the same, I was surprised at the performance gap between the two. The SiS 645 was significantly better all around; all of these scores were after I tweaked everything I could on both systems to achieve the highest scores I could.
its not same ati 9800 vs fx 5600
Reply 12 of 13, by Repo Man11
ciornyi wrote on 2026-03-16, 19:14:
Look at the images more closely.
Reply 13 of 13, by subhuman@xgtx
ciornyi wrote on 2026-03-16, 17:48:
Yeah it definitely is. Factory stock it only supports 400 fsb chips, but I adjusted the front side bus to 132.
This is a Biostar branded board (U8668 "pro") with an universal AGP 2x/4x slot. Perhaps good for a Voodoo5, but this is what I had laying around at the moment.
Your suggestion does make sense, especially with how bad memory bandwidth seems to be on a similar board to mine's.
