First post, by superfury
If I compare 80386 and newer processor documentation to for example Bochs or other x86 emulators, I get a complex behaviour that is effectively not or very badly documented in the x86 programmer reference manuals?
There's many things affecting interrupts, gates and instructions:
- Gate sizes
- Operand size prefix
- Address size prefix
- Default bit for stack
- Default bit for code
There's simple documentation for how the prefixes work with the D-bit, but for basic instructions only (like in real mode).
But all other cases result in very badly documented behaviour.
For example, interrupt documentation says it pushes 'SS:eSP'.
What stack decrements are used for that (4 or 2 bytes increase, 2 or 4 bytes written)? What about the SP vs ESP being pushed? Zero or sign extension, or truncation if any?
And what about Virtual 8086 mode interrupts, which doesn't document what happens when 16-bit gates are being used at all? Does it push 16-bit or 32-bit variables on the kernel stack?
The same for the issue of replacing an interrupt/trap gate with a call gate.
Then there's the reverse parts as well? RETF/IRET. Zero extending writing 32-bits EIP or stack pointer (ESP or SP) or leaving upper 16 bits unmodified (leaking them to user space)?
In fact, does 16-bits IP even exist on 80386+ processors?
UniPCemu Git repository
