First post, by BerkeleyGamecat
Hi all. First post here.
I'm resurrecting an old 486 system with a Biostar 1433/50UCV-E mobo. System is unbranded, but it was pretty well tricked out when new, with 4MB ram, 120MB HDD, VLB Floppy/IDE controller, VLB Mach64 Video, and ISA Sound/CD controller. I'd really like to get this beast rolling again.
Problem is that I get no response when I hook up a VGA monitor and power up. HDD spins up and CD door works, but nothing on screen.
I suppose that this could be a video card issue (hopefully not - I don't have a spare VLB video card lying around), but there is one other clue that baffles me. The POWER led does not light up. TURBO switch toggles the TURBO led on/off, but no PWR light. Other than the TURBO led, the only other indication that the board is alive is small 'D5' led on the corner of the board that lights up. Same symptoms when I first pull all three expansion cards.
Should I ignore the unlit POWER led, or is this the smoking gun? Power supply, or mobo?
I have a couple of spare AT power supplies, but they don't have a power switch and I'm not quite sure how to hook one up. Both have just Black/Brown/Blue/White wires with spade connectors. I can't reference my target system for guidance because its power switch leads have been soldered on.
Thanks for any guidance in advance.
Reply 1 of 2, by BerkeleyGamecat
Just to answer my own question here - it turns out that PS, video card, and mobo are apparently ok. I tracked the problem down to a bad jumper setting on the mobo that reported the cpu as CX486DX instead of CX486DX2, leading to erratic boot behavior.
Also, I figured out the switch wiring for my spare power supply. Thanks anyway.
Reply 2 of 2, by Horun
Good work !
