First post, by douglar
douglar
Offline
- l33t
I was trying to make a list of all of the PATA - SATA Bridge Chips that were ever out there in devices you could use to attach PATA to SATA
Here's my start---
Manufacturer Chip Direction Notable Characteristics--------------------------------------------------------------------------------------------------------------------JMicron JM20330 Bi-directional Most common chip today; widely cloned.JMicron JMD330 SATA Host Only connects legacy IDE drives to SATA motherboards.JMicron JMH330 PATA Host Only connects new SATA drives to legacy IDE motherboards.Marvell 88SA8052 Bi-directional Support SATA II & ATAPI, better compatability than the "040"Marvell 88SA8040 Bi-directional The Origional PATA SATA BridgeSunplus SPIF223A Bi-directional Best compatibility with old Xbox/PS2 consoles, 10% slower that Marvell & JmicronSilicon Image SiI3811 Bi-directional Supports ATAPI, hot-swap, and NCQ. Fast. Discontinued.Genesys Logic GL831a Bi-directional Bridges SATA and PATAGenesys Logic GL830 Multi-bridge Bridges USB 2.0, SATA, and when in 128-pin packaging, PATAAcard ARC-772 Multi-bridge High-end chip that can bridge SCSI/PATA/SATA
