First post, by fyredragon69
Hello all, after some time with my two computers (486 and Pentium MMX), I have finally settled on leaving Windows 95 OSR2.1 on my Pentium box, and Windows 3.11 on my 486. Because my Pentium box has PCI, I naturally put a period accurate NIC in there to easily copy files to the hard drive and whatnot. Unfortunately, it has been anything but easy. The machine came with a Realtek RTL8139 based NIC, which I thought was broken but seems to be just fine. After that, I swapped in a 3Com EtherLink XL card, which is known working, tried installing many different drivers, all of which didn't work. Every time I reboot the computer, start Windows and check device manager, I see the dreaded "yellow triangle exclamation mark" next to the NIC. As far as I can tell the drivers are fine, I've been obtaining them from The Retro Web, which I think is a reliable source. I've tried installing the TCP/IP networking stack for both NICs, no change. Is there something obvious here that I'm just missing? Help a noob out.
Thanks.
