First post, by Mourales
Hello everyone!
Yesterday I started cleaning the case chassis that I’m going to use for my new 486 project, and after wiping it with a damp cloth the result couldn’t have been worse.
I’m not sure whether the aluminium (or whatever material it is) has reacted with the water and ended up looking like it does in the photo.
Does anyone with experience have a solution for this?
Thank you very much in advance 😀
Reply 1 of 10, by wbahnassi
I believe that's the water...
Was it just water or something else also? (e.g. soap)
You can always spray it again if you want to.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 2 of 10, by SSTV2
You put this plate in the dishwasher with an alkaline capsule, didn't you? I can't imagine how else such amount of the zinc layer could have been etched away. There's not much you can do about it now, except to just replate the affected part or repaint the entire chassis.
Reply 3 of 10, by Mourales
SSTV2 wrote on 2026-03-24, 17:36:
Thank you so much,
I simply washed it by hand with water and hand soap. The strange thing is that when I submerge it in water, it looks perfectly fine. The problem appears when it dries. I am attaching photos.
I would be very grateful if anyone has any ideas.
Thanks again!
Reply 4 of 10, by Mourales
wbahnassi wrote on 2026-03-24, 17:05:
I believe that's the water... https://c.tenor.com/7Vsx6fQ0Ze8AAAAd/tenor.gif Was it just water or something else also? (e.g. soa […]
Thanks!
Reply 5 of 10, by wierd_w
Polish it with a leather chamois, like you would chrome on a car.
It looks like hard water and alum oxide layer. Mechanical polishing with a low abrasion buffer should shine it right up.
Reply 6 of 10, by Mourales
wierd_w wrote on 2026-03-24, 19:06:
Thank you!
Reply 7 of 10, by SSTV2
Wow, ignore my first comment, in the first picture it looked like the zinc layer was etched all the way down to the iron, but now it looks like that polishing would be enough here, as wierd_w suggested.
Reply 8 of 10, by wierd_w
Very important to not use an abrasive.
Soft leather chamois, and nothing else. Zinc is soft and easily damaged/stripped off.
Make sure there are no dirt particles on either the surface or the chamois.
Reply 9 of 10, by Mourales
SSTV2 wrote on 2026-03-24, 20:02:
Thanks a lot!
Reply 10 of 10, by Mourales
wierd_w wrote on 2026-03-24, 20:07:
Thanks a lot!
