Windows XP MCE 2005
First post, by sebada11
Hi, is there any way to run this edition on VMWare or VirtualBox without the video card incompatibility error? It occurs regardless of my hypervisor version. Neither using 3D-Analyze, SwiftShader or WineD3D help.
Reply 1 of 8, by Norton Commander
MCE 2005 runs fine in VMWare Workstation, I have it running on a Windows 7 x64 host. I never received any video card incompatibility error, it installs the default SVGA driver. You need to install guest additions if you want hardware acceleration AND your CPU needs to support hardware virtualization. Even if your CPU supports it you may need to enable it in BIOS, I had to do it on my Thinkpad.
Reply 2 of 8, by sebada11
Norton Commander wrote on 2026-03-26, 15:16:
The incompatibly error appears when I run WMC. My virtualization is obviously enabled.
Reply 3 of 8, by Norton Commander
Obviously not.
The attachment XP VMWare.png is no longer available
You should be seeing VMWare SVGA II as the adapter in the MCE guest after you install guest additions and all the Direct3D/DirectX tests should pass in dxdiag.
I also got it working in PCEM if you want to go that route.
The attachment PCEM1.png is no longer available
Reply 4 of 8, by sebada11
I 'm using WMWare Workstation 25H2 on my Windows 10 x64. I see the error "Your video card or drivers are not compatible with Media Center.". It appears in Media Center only. I've tested previous version of this hypervisor or VMWARE Tools and there hasn't been any change so far.
Reply 5 of 8, by ElectroSoldier
Patch the ehshell.exe.config file to remove the GPU check.
Its been a long time since I used XP MCE, I seem to remember it was a matter of just commenting out the Video Render validation.
Reply 6 of 8, by sebada11
ElectroSoldier wrote on 2026-03-26, 21:46:
How to do it?
Reply 7 of 8, by sebada11
I 've seen that ehsell.exe.config doesn't regard the video card compatibility.
Reply 8 of 8, by sebada11
Finally 've solved this issue. You need to add DisableDxCheck and DisableDx9CapsCheck values into Windows registry and copy all the .dll files from WineD3D archive apart from ddraw.dll. Therefore, it's a bit tricky, isn't it?
