First post, by Grimoz
Hi guys,
Im having issues at the moment and would appreciate any help possible, im trying to setup a P3 system with two sound cards, an ESS Solo1 for pure Dos and an Audigy 2 ZS for windows 98 SE, so far i have the ESS disabled and the Audigy works fine in windows using IRQ 5.
So here is the thing, when i go into dos it shows me the usual data for the ESS, 220 i7 D1 and that DMA Mode is TDMA. When i set this for certain games it works great, Doom for instance is flawless, as is Day of the Tentacle, my issues arise when i try games like Doom 2, Duke 3D, and Quake.
For example.
Doom 2 - I use the settings shown above, start the game and get music but no sfx.
Duke 3d - I cant even start this one unless i turn off sound, once again i use the settings above and continuously get the error Playback failed, possibly due to an invalid or conflicting DMA channel, ive tried everything i can think of but nothing seems to work.
Quake - No setup file for this one but the games starts but the sound glitches and sounds like its trying to do something but doesnt. I haven played around with this one so there may be a config file i have to edit.
I know the ESS works fine as ive used in windows.
Specs of the build are:
Gigabyte GA-6OXM7E Socket 370 Motherboard
Pentium 3 800EB Coppermine
128mb 133mhz RAM
Geforce2 MX400 64gb
Audigy 2 ZS
Ess Solo 1
Thanks in advance
