First post, by Linoleum
- Member
Hi everyone,
I recently picked up an unusual ISA VGA card and I’m hoping someone here might recognize it or have documentation, drivers, or background info. Card details:
- Manufacturer: STB Systems
- Silkscreen name: SPECTRADYNE CH1 1.0
- PCB marking: 1X0‑0228‑402
- Copyright: (C) 1993 STB Systems Inc.
- Chipset: Cirrus Logic CL‑GD5426‑80QC‑A
- Outputs: VGA, S‑Video, COAX
- Assembly date: 26/94 (Mexico)
- BIOS is attached (and mentions STB NTSC VGA rev2.06... and IBM... and AWARD!?!)
Here’s a photo of the card (you might have seen it floating on eBay):
What I’ve discovered so far:
- The S‑Video output works perfectly under DOS (tested DOS prompt, Doom, Wolf3d, Links386).
- The VGA output goes mostly blank after TV‑out is activated — sometimes I only get a blinking cursor at the top of the screen, which looks like the card is switching to 15 kHz TV timing.
- The card is correctly identified (CL‑GD5426) by NSSI and univbe.
Interestingly, SVIDEO works most of the time, but I've seen one exception: when displaying the PCX splashscreen image when launching Direct Access 5. When this happens, this is the only time the VGA image comes up and shows the previous mode 80 image (in this case the menu itself). Very weird... But it proves the VGA output works!
What I’m looking for
- Any documentation, or OEM manuals mentioning Spectradyne CH1
- STB driver disks that might include TV‑out utilities
- Information about whether this card supports VGA + TV simultaneously, or only one output at a time
- Any historical context about this specific STB multimedia line
If anyone has seen this card before or has old STB OEM driver floppies lying around, I’d love to hear from you. This seems to be a pretty obscure piece of early‑90s multimedia hardware.
Thanks!
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
