douglar wrote on 2026-04-01, 14:18:
There's a lot of different makes, there's probably one out there that's perfect for your build, but good luck finding it.
I don't feel it's a matter of luck, so much as finding what works and sticking with it.
My own strategy has been buying up used lots of CF cards and/or NOS cards (typically Sandisk) from Ebay. I also stocked up on Verbatim branded cards from Amazon back when they were available a couple years ago.
I've used these on systems ranging from Turbo XT Tandy 1000 up to Pentium MMX systems.
For my Tandys, I typically use the low capacity Cisco Industrial cards (32/64MB). 286 systems I think I've used up to 128MB. Those systems require XT-IDE BIOS extensions.
For 386 and 486 systems I typically stick to 512MB or less, though I think one of my 486 systems I used a 1 or 2 GB card. These would be the regular Sandisk cards.
For Pentium / Pentium MMX I mostly use 2GB or 4GB Verbatim cards. I've also tested a 4GB Verbatim card with my Pentium 4 system, though ultimately didn't include it in the final build.
I've installed CF cards on well over a dozen different systems and they'll all worked, as long as I stick to appropriate brand cards and sizes for the respective systems.
