First post, by kotel
- Oldbie
Hi
recently I got a Seagate sata hdd with server 2k3 small business server installed on it, which had a few programs only accessible from the installed OS (so I can't plop it in another system and run them from it). Drivers which I found on it make me believe it was run in RAID on a gigabyte GA-M61MSC.
Here's what I tried so far (chronological order):
Apply the PCIIDE.reg patch (verified if it actually integrated)
Change the SATA controller to AHCI, IDE/compatibility and RAID operation on countless mainboards
Integrate the ITE 8712 RAID driver for my mainboard gigabyte 8i945G to the system (.sys file copied into SYSTEM32\drivers directory and additional registry entries)
Converted the drive from RAID 1 to normal
Try it in two other MCP61 boards (set to IDE mode since I don't have the other HDD)
But all resulted in the dreaded 0x7B BSOD
Any ideas how can I make it work in IDE mode?
Always has the weirdest issues happen, and always is all alone with them
