First post, by tomcattech
- Member
Compaq Presario 5000
P3 \1000 with "Integrated AGP" on the mobo
Came in looking shabby and wouldn't boot up due to the 15 pin video out header hanging on to the mobo via 2 pins.
Replaced the header and boots up fine...
Did a quick retro bright job to some areas of the case
OS: WinME system restore
No AGP slot so now I'm in the process of finding a grade A PCI sloution.
VPR Matrix (Best Buy In House) P4 1.8
Was in really bad shape from the Bay except for the case.
PSU: Shot
CD1: Shot
CD2: Shot
mobo: Cooler mount broken and cpu cooler laying in the bottom of the unit
mobo: Bad trace that needed repair
OS: Win98 SE Quickinstall
Up and running but all I had left in spares for a GPU was a crappy GFX 5200.... So it needs something else at some point
I either fix it or break it permanently... there is no try.
