First post, by MegaMobian
Hey, y'all.
Welp, this is my very first message here (so please forgive me if this is in the wrong forum, I have no idea what I'm doing. . .) Anyways, I have a Gateway LE500 CRT monitor that I want to use instead of my DELL LCD for my Windows 98 PC build (y'know, for a more authentic feel), but whenever I try to plug it into my graphics card (an ATI Radeon 9250 PCI) it shows "no signal." The card works just fine with the LCD, but for some reason it just does not want to cooperate with the Gateway monitor. The Gateway monitor will work with the onboard graphics just fine, so I don't think it's a problem with the monitor itself. I've tried messing around with BIOS settings. I've tried making sure the VGA cable has a good firm connection to the Radeon's VGA port. I've tried reseating the graphics card. I've even tried uninstalling the card, drivers and all, and reinstalling it. No dice, unfortunately. . .
The strange thing is that I noticed that Windows had installed drivers specifically for the DELL monitor, so I thought "oh, well maybe if I uninstall those drivers it'll work just fine." It did not. So, then I thought "maybe I just need to install the drivers for the LE500." That didn't work either.
I'm really at a loss here, and any suggestions would be much appreciated.
Reply 1 of 14, by BitWrangler
Is monitor working otherwise, seeing POST screen, works when you boot to command prompt? Just blanks out in Windows. Or have you got nothing at all when plugged to this card.
Reply 2 of 14, by DaveDDS
Since the monitor works on the on-board port, it's probably not a bad monitor or cable (I;m assuming you are using the same cable in both cases). Since the Dell LCD works on the graphics card, it's probably not a bad card.
I suspect it's some incompatible signalling ... perhaps resolution, refresh rate, sync polarity or any number of factors.
Graphics cards usually come with a setup/adjust tool that works with their drivers to adjust many aspects of the video signal.
Assuming you have this, you could take a look and see what it can adjust - you might have to "play a little".
Been so long since I worked seriously with W98 - does it support two monitors on two separate video interfaces?
If you could get such a setup working, it would make it a lot easier to "try things" without constantly having to lose video and move cables.
good luck!
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 3 of 14, by MegaMobian
BitWrangler wrote on 2026-04-10, 02:37:
Nothing at all. Just a blue box with white text that says "NO SIGNAL."
Reply 4 of 14, by BitWrangler
This sounds weird, but you can try the magic reset for confused digital detection CRTs... lick your thumb, wipe it so so it's just damp, then plant it firmly on the end of the VGA cable, pushing hard enough to contact all the pins... there are some theories that the digital circuits get hung up with static buildup or something... putting the one megohm approx thumb resistor across the pins to the shell bleeds it out.
Reply 5 of 14, by MegaMobian
DaveDDS wrote on 2026-04-10, 02:51:
Since the monitor works on the on-board port, it's probably not a bad monitor or cable (I;m assuming you are using the same cab […]
good luck!
The uncooperative monitor in question actually has a built-in, permanently attached VGA cable, if that makes any difference.
As for using two monitors on separate video interfaces with Windows 98, I believe (if my memory serves) I've looked it up before, and can recall discovering that you could. I'll have to check again, though.
Also, I'll definitely try what you suggested with the ATI control panel to see if that helps. Thanks for the support, man!
Reply 6 of 14, by MegaMobian
BitWrangler wrote on 2026-04-10, 04:51:
I'll have to try that. Thanks, man! As stated before, anything helps, no matter how seemingly outlandish!
Reply 7 of 14, by NeoG_
Is the DELL monitor also using VGA? Or DVI?
Reply 9 of 14, by NeoG_
Unless you have confirmed there is something else that can show up on the screen my gut feel would be an issue with the cable
If the monitor is new enough to have a “no signal” message it will also have an “out of range” message if the signal is beyond the capabilities of the screen
Reply 10 of 14, by BitWrangler
Yeah I would try swapping the cable over, I've seen some with fatter pins than others. Once those have been put into a card, the socket gets strained a little and the thinner pins don't contact well. Either that or the others were undersized in the first place and only work on fresh graphics cards. Also when you get a card that's been frequently plugged and unplugged over the years it can be a bit picky about what plugs it likes due to wear. Ultimately the VGA connector may need to be replaced on cards like that. I have a Paradise Bali 32 in that sort of state at the moment. But, contact cleaning can often help things out, either with alcohol or contact cleaner spray.
Reply 11 of 14, by DaveDDS
MegaMobian wrote on 2026-04-10, 04:51:
... The uncooperative monitor in question actually has a built-in, permanently attached VGA cable, if that makes any difference ...
Unfortunately it does - in that you can't easily test a different cable. As someone else pointed out cables & connectors can become "slightly damaged" where a particlar set of contacts don't make a good connection.
Have you tried "wiggling" the cable, ie: putting some pressure up/do/sides? don't tighten hold-in screws if it has them, and try holding the cable side of the connector in each direction with the system powered on an showing video (you could get this set up using your LCD monitor and just swap cables to test)
Reply 12 of 14, by MegaMobian
BitWrangler wrote on 2026-04-10, 14:02:
. . . But, contact cleaning can often help things out, either with alcohol or contact cleaner spray.
I've tried that before to no avail, but I guess it's always worth another shot.
Reply 13 of 14, by MegaMobian
DaveDDS wrote on 2026-04-10, 14:14:
. . .Have you tried "wiggling" the cable, ie: putting some pressure up/do/sides? don't tighten hold-in screws if it has them, and try holding the cable side of the connector in each direction with the system powered on an showing video (you could get this set up using your LCD monitor and just swap cables to test)
I'll make sure to try that too, I just still have to reinstall the ATI drivers first.
Reply 14 of 14, by MegaMobian
. . .Graphics cards usually come with a setup/adjust tool that works with their drivers to adjust many aspects of the video signal.
So I reinstalled the drivers and tried messing around with the ATI control panel, but the only useful settings are screen resolution, color depth, and refresh rate, all of which are at the lowest settings (the other settings are screen size, position, and rotation; color profiles; Direct3D; etc., none of which I think are probable sources of the problem.) Should there be even more advanced settings to adjust here, or am I missing something?
