After some testing i have to say for now that the machine bios goes nuts,and the gotek is not faulty , nor Ontrack is faulty, nor the floppy drive is faulty.
The machine is a ps/1 2168 and according to manuals it was sold with a 300mb to 400mb hard drive.
1) when using a CF to IDE adapter and a CF card of 512mb, (period correct capacity) , the bios detects that amount perfectly. I am able to use the real floppy drive and floppy discs without any problem and changing floppy disks and doing DIR updates the content.
2) When using a CF to IDE adapter and a CF card of 1GB, (not time perior correct), the bios does show 1gb amount, i am able to use the real floppy drive but that is when things go nuts, changing the floppy disk and doind DIR does NOT update the drive content.
3) Using a sintechi SD to ide adapter and a 1gb kingston original SD card, the bios detects it as a 5megabyte hard drive. i am able to boot dos 6.22 floppy, create partitions with fdisk, format c: /s , but the machine just refuses to boot from hard drive.
the only way to make the sintechi SD to IDE adapter with the 1gb sd card work, was to use HDD raw copy tool, make a backup of the 1GB CF card, and dump it on the 1GB SD card, only then the sintechi sd to ide adapter started working and loaded windows 3.11. but again, in DOS, if you change the floppy disk , it still shows the incorrect contents.
so the only real possible solution would be to:
1) install and use an XT-IDE
2) or live with the floppy drive not changing the content and pressing Control+C and doing dir again.
3) or using TurboImage 1.01a
so far a am happy with a 1gb SD card (having two partitions of 500mb ) and windows 3.1
so i think that if i want to install something multi-disk under DOS..... i will just use turboimage and keep the benefit of 1gb of space.
