First post, by VanillaFairy
- Newbie
I'm planning on upgrading the parts from an old Sony VAIO I have (the whole thing is disassembled but I would like to keep the motherboard which is an ASUS P4S533-VX) to make a retro gaming rig, and my options for a CPU upgrade that I can find evidence of existing on both eBay and The Retro Web seem to be around a 3 or 3.2 Ghz Northwood Pentium 4 at a 800 MHz FSB speed, or a 2.8 GHz Pentium 4 at only a 533 MHz FSB speed.
Since the motherboard only supports Northwood chips (according to The Retro Web, although I don't have a Prescott P4 (or any P4 really) to test it with) and has a 533 Mhz front-side bus, would the lower-clocked P4 with a matching FSB speed run better or should I instead get the higher clocked northwood chip?
(also in a similar vein, would trying to get a GT 720 in the PCI slot with a bridge adapter (since its power draw is low enough) be a better choice than trying to find a probably more expensive AGP card to fit in?)
Currently the CPU installed is a 2ghz Celeron 4 (so any upgrade would probably be a great one tbh for it) and the GPU it has is a Radeon 7000
Just a silly lil person in a very big world.
