First post, by Shponglefan
- l33t
Lately I’ve been experimenting with various Pentium 4 hardware combos and throttling capabilities. This is largely due to the recently released P4Tool by OttoPS available here: Re: [b]p4tool - performance control utility for Pentium 4 / NetBurst[/b]
I’ve been wondering how slow a Pentium 4 can be throttled without relying on ACPI or ODCM throttling.
In testing with my i865 and Pentium 4 651 HT (Cedar Mill) setup, I could get down to speeds approximating a slow 486. I really want to see if it's possible to hit 386 speeds ideally the equivalent of a DX-25 or DX-33.
To that end, I’m testing a recently revived DFI ITOX G4E620-N motherboard with a 2.0GHz Pentium 4 (Northwood) processor. The nice thing about this board is it features both a working AGP x4 slot and three ISA slots with DMA support.
I was also inspired by Phil’s 136-in-1 Pentium MMX project, where he mentions using ISA cards to achieve slower performance levels. So I decided to try ISA VGA cards on this board to see how slow it can go, and how it compares to AGP or PCI cards.
One of the challenges with using an ISA video card is they tend to be the default video option, overriding either AGP or PCI. However, after reading about potential ways to disable that using jumpers, I discovered one of my cards, a Diamond Speedstar VGA (Tseng ET4000AX)) could be prevented from loading its video BIOS by removing the BIOS timing jumper.
On that note, I’ve been testing a triple GPU setup using a GeForce 4 MX440 SE (AGP), Voodoo3 3000 (PCI), and Diamond Speedstar VGA (ISA) concurrently.
In terms of performance, the ISA VGA card has a lower top end for performance compared to the AGP card. As the CPU is throttled to lower levels of performance, the gap narrows. At the lowest level of performance, there is only a 0.1 framerate (3%) difference in the PC Player benchmark.
I also tested a variety of ISA cards and a few PCI cards with the CPU highly throttled. For the most part everything was within a few percent of each other. The only exception was the Oak VGA 037c card.
One issue I ran into was using sound cards at the same time as the ISA video card. I tested three different YMF-71x cards. In playing Decent, two of them stopped playing digital audio and would get stuck on GM playback. Only one of the three would playback properly. All three cards worked fine with the AGP video card.
I also tried an Orpheus I and AWE64 sound card. Both of these seemed to work fine alongside the ISA video card. But I will need to do a lot more testing to see if I run into any issues.
Overall, I don’t know how practical a setup this is. At the lowest levels of throttling, there isn’t much difference between AGP, PCI and most of the ISA video cards. I still need to test out a variety of games to see how well things performed throttled and in conjunction with ISA video and sound.
I further want to test 1.6GHz and 1.8GHz P4 processors to see how they compare to the 2.0GHz Northwood, though I'll need to obtain those processors first.
