First post, by *skyvlan
Hi, i recently acquired a rebranded Soltek SL-54A2 based OEM Socket 7 Motherboard based on Intel 430VX, and i'm unable to get my PCI Network cards (RTL8139D) and Sound cards (CMI8738) to work, they do work on DOS however but my BIOS doesn't assign IRQs automatically to my cards and i don't know what to do
Each time i search for a new hardware however, they are detected but the drivers don't work
Reply 1 of 7, by *skyvlan
also to clarify, my S3 Display works even without IRQ assigned by the BIOS, is this a Driver issue or a IRQ issue?
Reply 2 of 7, by NeoG_
An IRQ shoul dbe assigned at boot time, I would start by clearing the CMOS in case the PnP assignment table is messed up
Reply 3 of 7, by *skyvlan
I tried to reset the CMOS and seems like it still doesn't assign an IRQ to my cards
I can't seem to find an option called PnP OS or anything
Reply 4 of 7, by Grzyb
Display Controller can work without IRQ.
But I don't think the Network Controller can.
And the BIOS can't see the sound card at all.
So, yes, resetting the CMOS is a good idea.
And then you can try swapping the slots for the NIC and the sound card...
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
Reply 5 of 7, by *skyvlan
I've reset my CMOS and changed the pci slots seems like all my devices are detected now but still no IRQs are assigned
Reply 6 of 7, by NeoG_
Can you try and change "Resources controlled by" to Auto
Also I assume you have intentionally disabled the second IDE channel? Usually IRQ 14 and 15 would be used by the onboard IDE controller after resetting to default
Other things you can do is clean the PCI slots (put contact cleaner on the PCI cards and do 5 insert/remove cycles) and also try and re-flash the BIOS with the latest version
Reply 7 of 7, by *skyvlan
NeoG_ wrote on 2026-04-19, 11:29:
Yeah, i've disabled the second IDE channel and changed the resources controlled by to Auto, still IRQ assigned, which is weird.
I've reflashed it to a newer version and it didn't change much
