First post, by smoke86
Hi,
I recently aquired a FIC 486-GIO-VT2 motherboard and it does seem to have a IDE controller problem. This board has onboard IDE controller with2 channels.
I tried many IDE cables (both 40 and 80 wires) with two HDDs (10GB and 202MB, both set to Master) and one CF adapter with 1GB card (works as system disk with other DOS system) and I cannot get it to work with primary channel - nothing is being detected.
On the secondary channel disks are being detected (post screen shows those properly), but when I run fdisk there is nothing there - no HDDs detected.
BIOS has weird quirk with HDD detection - it decects HDDs as C, D, E, or F instead of primary master, primary slave etc.
I will fiddle with onboard jumpers, clean the contacts etc. If that won't work, I will try disabling IDE channel and try an ISA controller.
I have never encountered this problem before, please help.
