Universal Chipset Patcher 2.0.5 (PCI/ISA)
First post, by Rav
Hi there
UCP 2.0.5.1 :
The attachment ucp2.zip is no longer available
Screenshots from my MMX
The attachment ucp2_1.png is no longer available
The attachment ucp2_4.png is no longer available
I got my new UCP in a state that in can finally be published.
The new version is compatible with the following PCI chips:
[Northbridge]
- ALi M1429 (and G version)
- ALi M1489
- ALi M1521
- ALi M1531
- ALi M1541
- Intel 440BX
- Intel 440EX
- Intel 440FX
- Intel 440LX
- Intel 440ZX
- Intel i815
- Opti 82C802G
- Opti 82C895
- SiS 471
- SiS 496/497
- SiS 5511/2/3
- SiS 5571
- SiS 5581/2
- SiS 5591/2
- Via 82C495G
- Via 82C570M
- UMC UM8881F
[Southbridge]
- ALi M1523
- ALi M1533
- ALi M1543
- Intel PIIX
- Intel PIIX3
- Intel PIIX4
- Intel ICH2
- SiS 5595
- UMC UM8886/A/N/F/BF
[VL to PCI Bridge]
- Ali M1435 (Stub - Documentation missing)
- Opti 822
- VIA 82C505
[Video cards]
- S3 Trio64
- S3 Trio64 V2 DX
- S3 Virge DX
[IDE Controller]
- IDE chunk of UMC UM8886AF
[CPU]
- Cyrix 5x86
If you have any idea for improvement or request for chipset, please let me know
Utilisation, you won't be lost, if you ever used Award BIOS. Settings are saved in the same folder as the .exe. Once you made configurations, you can put the thing in the autoexec.bat with /autoload switch, to just load the configured settings.
There is a memory test tool in the program, but it's still alpha-ish and ugly. If you want to test new memory timing/speed settings in memtest86+, you can simply boot using something like QEMM, set the settings and press ctrl-alt-del, it will fastboot (instantly load memtest from the flop) without going back to the BIOS, preserving all settings. If you do that, be sure to not have network drivers loaded as they also don't get reseted and they will DMA packets in the RAM, failing the test.
Note that I have only tested on Ali M1531/M1533 (My system). Settings in yellow in the screenshot are what I changed (Gained 1.5fps on Quake yay!)
Here a chip support file :
The attachment ali1541.c is no longer available
I welcome peoples making some for other chips that are not listed, and I will add them to UCP2.
User loadable files are planned to be supported in a future version (once I have all structures for all the supported way of patching stuff implemented and stabilised).
Here an example of a register setting for a freetext format (digit between 0 and 31)
"PCI Latency Timer",
"Controls the amount of time the M1531 can burst data to the PCI Bus.",
0, 0, 0, 0x0C, // Bus, Dev, Func, Reg
0xF800, // Mask: Bits 7-3
11, // Shift: 3 bits
0, // opt_count: 0 (not used)
{ {NULL, 0} }, // opts: Empty/Unused
0, // current_idx: current or default value
0, // default_idx: default value, populated and first launch from the currently configured setting by the BIOS
INPUT_TYPE_FREEFORM, // It's a number input
0, // Min Value
31 // Max Value
Bus, Dev, Func will be removed in the future, just set it all to 0,0,0
Here another one for a setting with choices:
"Refresh period", "Period to refresh DRAMs. Longer delay = faster operation.",
0, 0, 0, 0x44, 0x0700, 8,
5, { {"1024 Clk", 0},{"2048 Clk", 1},{"4096 Clk", 2},{"8192 Clk", 3},{"16384 Clk", 4} }, 0, 0,
INPUT_TYPE_LIST, 0, 0
Note to people wanting to help submitting chip files.
PCI Configuration mode is accessed via 32 bits chunks and x86 is little endian. So here how to properly set the register
Example register 0x44, bit 2-3.
You take the register from the doc, 0x44, and do "mod 4". you endup with "0", so you do as simply as:
Register "0x44", mask "0C" and shift "2"
Example register 0x46, bit 2-3
0x46 mod 4 is equal to 2, so you have to shift all the stuff 2 times 8 bits on the left
You write it as register "0x44" still (You can also write 0x46, my program do chop the two last bits of the register digit.)
Mask would be "0x0C0000"
shift would be "18" (2 + (2 * 8 ))
5/4/26 : Updated UCP2
- Simple hotfix to fix a bug in the screen configuration restoration (when user exit the TUI). It won't leave you with an invisible cursor anymore if you disable "UCP Settings > Restore screen framebuffer".
- Added part of planned IO Port type register configurations (nothing to see there, yet)
5/5/26 : Updated UCP2 to 2.0.1
- IO PORT support other than PCI Configuration mode supported
- ISA chipset supported (none implemented)
- PCI adaptors supported
- Save file format updated to support the IO Port stuff and ISA devices (Old format is converted to the new one if you already have a save file).
Added the following chipset
- 440EX
- 440FX
- 440LX
- 440XZ
- PIIX3
- PIIX
Added the following video cards
- S3 Trio64
- S3 Trio64 V2 DX
- S3 Virge DX
5/22/26 : Updated UCP2 to 2.0.2
- Changed the option page layout to optimize available space for option strings
- Removed shilly abbreviations as they are no longer needed
- Added a few SiS chips (5511/2/3, 5571/2, 5581/2, 5591/2, 5595)
- Update save format (Older saves are converted)
5/25/26 : Updated to 2.0.4
- Allow system without PCI to select there ISA/VL chipset from a popup on first launch, with a list of ISA chipsets
- Updated the save format so proper ISA support
- Added a mechanism to support slow PCI boards (the ones with PCI bridged behind a VL Bus). These are still considered PCI but do show a popup to allow user to select there ISA northbridge (It show possibly compatible chipset, for example if you have a Via 82C505, it will allow you to choose between Via 82C496G and 82C570M... It won't show Opti or Ali options.)
- Added a few chips (Ali M1429/G, Ali M1489, Opti 802G, Opti 822, Opti 895, SiS 471, SiS 496/497, Via 82C496, Via 82C570M, Via 82C505, UMC 888*)
5-28-26 : Updated to 2.0.5
- Fixed minor bugs
- Fixed the main config loading loop (it only affected users with 2 configured ISA devices or more, so... no one!)
- Fixed a race condition for loading configuration on pure isa hardware (ugly fix as using volatile and memory barriers did not work)
- Added ISA/IO Ports devices (UMC UM8886AF and Cyrix 5x86)
5-29-26 : Updated to 2.0.5.1
- Hotfix (Cyrix 5x86)
- Hotfix (UMC 8886BF is a 8886A coupled with an extra internal PCI IDE controller on a "different" PCI device)
Reply 1 of 41, by marxveix
Does it work cheaper Intel 440 chipsets, like 440zx/440lx/440ex?
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 2 of 41, by Rav
marxveix wrote on 2026-04-28, 10:01:
Support for more chipsets will be added soon.
Code for chipsets are specific and pinned to them by there VID/DID.
Edit : half support is implemented. If you don't have a supported northbridge, but have a supported southbridge, you will see the setting for the southbridge. And vise versa.
If you configure for say the PIIX4, and later update for a new version that support the 440EX, then the configuration you did for the PII4X will be preserved.
Reply 3 of 41, by carlostex
Oh wow, this is something i really want to try out. My main retro system is a 430TX chipset which uses the Intel PIIX4 southbridge. I'm wondering what options are available to tweak.
Reply 4 of 41, by jheronimus
Would be cool to have custom chipset register files like in TweakBIOS or wpcredit. This way users will be able to contribute files for various esoteric chipsets.
MR BIOS catalog
Unicore catalog
Reply 5 of 41, by Rav
jheronimus wrote on 2026-04-28, 20:28:
I do plan to have external files support in the future.
In the form of a binary format that would contain all the needed stuff.
It's not available yet as I'm not done with all the needed stuff (right now it only support registers in the PCI Configuration mode, no I/O registers or other fancy stuff).
Once I have all the stuff supported and all array structure defined and stable for everything, I plan to release a program that convert between text and binary (both directions)
The files will be in a "chips" subdirectory and UCP2 will scan theses to see if they support some of the present PCI devices.
The save format is already made in a way to support user modifications of registers definitions (it will still load and apply even if the definition get updated to add more stuff, and will also work if the order of the entries in the file change. Only saved stuff that is removed from the files don't get loaded/applied.).
Here is a current built-in file. Feel free to create new one and I can integrate it in the current version.
Reply 6 of 41, by Rav
Here the support file for the PIIX4 :
The attachment piix4.c is no longer available
Northbridge are.. more interesting but...
It have few ISA stuff, and a lot of IDE timing stuff (Backup your stuff before testing that please)
Reply 7 of 41, by jheronimus
Rav wrote on 2026-04-28, 21:11:
Nice! I'll try to mess with it on the weekend and add SiS 600, that one really benefits from this.
MR BIOS catalog
Unicore catalog
Reply 8 of 41, by Rav
shift would be "18" ( 2 + (2 * 8 ))
Reply 9 of 41, by Rav
Updated UCP2
Reply 10 of 41, by StuckIn1999
This is pretty cool stuff
Does it talk directly to chipset registers or uses a bypass?
Reply 11 of 41, by Rav
StuckIn1999 wrote on 2026-05-05, 08:22:
Right now it talk to the Chipset using the PCI Configuration Mode (IO at 0xCF8 / 0xCFC) and only support PCI chipsets.
The version I am working on can also talk to PCI adaptors and ISA devices via IO Ports ( It's going to be available soon including support for some S3 cards Pedestal bit fix mentioned here : https://bitsundbolts.com/2026/04/23/fixing-th … l-bit-bios-mod/ Funny enough I noticed that many of the S3 on 86Box have that bit enabled but they don't emulate the feature. ). Just doing some extra polishing and testing before releasing
Reply 12 of 41, by Rav
UCP2 has been updated!
changelog:
- 440EX
- 440FX
- 440LX
- 440ZX
- PIIX3
- PIIX
- S3 Trio64
- S3 Trio64 V2 DX
- S3 Virge DX
Reply 13 of 41, by aVd
Rav wrote on 2026-05-05, 16:29:
Hi, @Rav,
With all my respect to the retro hardware repair work of @BitsUndBolts, his a.i. based videos are... let's say it this way - not a good source of reliable information. The last ones of his videos about S3 ViRGE and Trio3D video cards are just somehow working mumbo-jumbo shady exercises based on a.i. slop.
Briefly, here's what I have about so called "S3 BIOS bright bug":
For the older S3 cards based on Trio64V2/DX, ViRGE/DX, ViRGE/GX chips the "pedestal bit" in 0x03C5 register is this one: x x B x x x x x (the sixth bit if we count from the least significant bit starting from one). So, to cure the "bright bug" in the safest way, we have to use bitwise operation "AND 0xDF" (oxDF = 1 1 0 1 1 1 1 1) applied to the register 0x03C5. This way we don't change any other previously set bit values in the register.
Working assembly code for disabling "bright bug" on S3 Trio64V2/DX, ViRGE/DX, ViRGE/GX
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,1A
OUT DX,AL
INC DX
IN AL,DX
AND AL,DF ; dis. BB
OUT DX,AL
The safest reverse bitwise operation enabling "bright bug" for the same older S3 card is with "OR 0x20" (0x20 = 0 0 1 0 0 0 0 0) applied to the same register 0x03C5. This way we don't change any other previously set bit values in the register.
Working assembly code for enabling "bright bug" on S3 Trio64V2/DX, ViRGE/DX, ViRGE/GX
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,1A
OUT DX,AL
INC DX
IN AL,DX
OR AL,20 ; en. BB
OUT DX,AL
Important note: The above dosn't apply to the very first ViRGE/325 (86C325) chip! Possibly due to different register's settings.
For the newer S3 cards based on ViRGE/GX2, Trio3D and possibly even Savage(4) chips the "pedestal bit" in 0x03C5 register is this one: x x x x B x x x (the fourth bit if we count from the least significant bit starting from one). In this case, to cure the "bright bug" in the safest way, we have to use bitwise operation "AND 0xF7" (oxF7 = 1 1 1 1 0 1 1 1). We don't change any other previously set bit values in this register.
Working assembly code for disabling "bright bug" on S3 ViRGE/GX2, Trio3D
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,27
OUT DX,AL
INC DX
IN AL,DX
AND AL,F7 ; dis. BB
OUT DX,AL
The safest reverse bitwise operation enabling "bright bug" for the same newer S3 cards is with "OR 0x08" (0x08 = 0 0 0 0 1 0 0 0).
Working assembly code for enabling "bright bug" on S3 ViRGE/GX2, Trio3D
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,27
OUT DX,AL
INC DX
IN AL,DX
OR AL,8 ; en. BB
OUT DX,AL
I hope the above examples are clear enough. I have assembled utilities for enabling/disabling the mentioned "bright bug" affected S3 cards, but this is topic for a new thread.
Thanks for your work on the chipset patcher tool!
EDIT: The correct "bright bug" register is 0x03C5, not 0x03C4.
SvarDOS fan :: artificial "intelligence" bots - not a fan at all :: say NO to systemd :: is freeware a lie, when human freedom is a fundamental lie? :: f00ck €u!
Reply 14 of 41, by Rav
aVd wrote on 2026-05-06, 04:58:
Hi, @Rav, With all my respect to the retro hardware repair work of @BitsUndBolts, his a.i. based videos are... let's say it this […]
Hi, @Rav,
For the older S3 cards based on Trio64V2/DX, ViRGE/DX, ViRGE/GX chips the "pedestal bit" in 0x03C4 register is this one: x x B x x x x x (the sixth bit if we count from the least significant bit starting from one). So, to cure the "bright bug" in the safest way we have to use bitwise operation "AND 0xDF" (oxDF = 1 1 0 1 1 1 1 1). This way we don't change any other already set bit values in the register.
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,1A
OUT DX,AL
INC DX
IN AL,DX
AND AL,DF ; dis. BB
OUT DX,AL
The safest reverse bitwise operation enabling "bright bug" for the same older S3 card is with "OR 0x20" (0x20 = 0 0 1 0 0 0 0 0) applied to the same register 0x03C4.
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,1A
OUT DX,AL
INC DX
IN AL,DX
OR AL,20 ; en. BB
OUT DX,AL
For the newer S3 cards based on ViRGE/GX2, Trio3D and possibly even Savage(4) chips the "pedestal bit" in 0x03C4 register is this one: x x x x B x x x (the fourth bit if we count from the least significant bit starting from one). In this case, to cure the "bright bug" in the safest way, we have to use bitwise operation "AND 0xF7" (oxF7 = 1 1 1 1 0 1 1 1). We don't change any other already set bit values in this register.
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,27
OUT DX,AL
INC DX
IN AL,DX
AND AL,F7 ; dis. BB
OUT DX,AL
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,27
OUT DX,AL
INC DX
IN AL,DX
OR AL,8 ; en. BB
OUT DX,AL
Hi.
Yeah, in my code I only change the one specific bit.
I also did not try to patch it on the original virge.
I am going to add the code for the GX2 too for next update, thanks.
Reply 15 of 41, by aVd
I just tried to briefly explain with tested and working examples, that the "pedestal bit" for S3 Trio64V2/DX, ViRGE/DX, ViRGE/GX chips in register 0x03C5 is one and the same, but differs from the "pedestal bit" for next generation S3 ViRGE/GX2 and Trio3D chips in the same 0x03C5 register. This is not clearly explained in the BuB's videos based on a.i. web searches.
Reply 16 of 41, by NeoG_
I have an M1541/M1543 mainboard with a K6-2+, I'm already using CTU to enable write combining, MTRR and ordering - Are there any additional northbridge/southbridge settings accessible with this a[[ that can eek out a bit more CPU efficiency?
Reply 17 of 41, by Rav
NeoG_ wrote on 2026-05-07, 05:42:
Plenty of stuff to play with including memory timing, to much to list here. Here, have the ali1541.c
The attachment ali1543.c is no longer available
Reply 18 of 41, by Rav
Here is the new upcoming version (with TUI change).
The attachment 2026-05-19_01-06.png is no longer available
I did keep the main menu as is, like an Award BIOS kinda), But I changed the submenu where one can change the setting.
I am still not fully decided if I should keep it like that, now it fix the issue on where I needed to "compactize" the different setting names, as showed by the red arrow in the screenshot, or replace the Enabled/Disabled by ON/OFF to save space because the left column was less than 40 characters long...
But well, I find the list maybe too small I don't know.
Should I ditch the help and add an "press F1 for help" or keep it like that.
I am thinking about adding actual support for 50 lines mode and keeping the help only for 50 lines mode...
For sure I do plan to also add a scroll bar on the right instead of the little up/down arrow for scrollability indicator.
Any recommendation / preference ?
[Edit] Actually most of the option in that screen shot are "compacted"... Buff, BusIdle, Fcn, WB...
[Edit 2] Now I am thinking, maybe no help by default, but split the screen in half if the user press F1, and it stay like that for the session.
Reply 19 of 41, by maxtherabbit
I like it how it is in the picture, but I don't like the weird abbreviations. Keep the help and use full words in the setting names
