First post, by Violett'Blossom
So after finally finding a second working Radeon HD4890 card for my current AM2+/AM3 build, I discovered that the core of the R10 inductor has broken off in shipping. Is it okay to just glue it back together if the coil itself isn’t shorted or should I look for replacement part?
The coil reads 27 ohms just like the second coil but i have no device to measure inductance.
Any input is hugely appreciated 😀
XP machine: Phenom II X4 965, 4890 Crossfire
Main: TUF Dash F15, I7 11.gen, RTX 3060 6GB
Reply 1 of 2, by shevalier
Take a look at where the traces from this inductor lead.
If it’s a 6/8-pin +12V connector for the graphics card, then there’s no problem.
My apologies, I wasn’t paying attention.
This is clearly a high-current inductor with a resistance well below 1 ohm.
If the coil is broken, it needs replacing.
Some thing like thats https://imrad.com.ua/ua/jrpi0604m-r82m-586368
If only the core has snapped off and it’s located right at the connector’s input, it can be glued back together.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 2 of 2, by rasz_pl
1 I dont see crack on the picture?
2 https://www2.vgamuseum.info/index.php/f-naq/i … -radeon-hd-4890
3 If its the ferrite part cracked then yes you can glue it up. Think of it like a broken magnet - stick two pieces together and it still works like a magnet. Or like electric motor stator/transformer core - build from individual slices of steel to reduce Eddy Current losses.
4 R10 inductors in this card are used to filter incoming 12V.
5 Yes as shevalier said coils/inductors are MEANT to be shorted 😀 if its not reading short then its open aka broken 😀
