First post, by Vinny Da Pooh
HI everyone,
I'm trying to repair a disk drive for the Commodore 1541-II (for Commodore 64), and I’ve run into a strange issue.
From what I can see (based on diagnostics/screenshots), the head reads between tracks quite well, but does not align with the actual tracks.
The behavior is consistent across all tracks (from track 1 to 35):
- I cannot read any whole-number tracks
- I can read all half-tracks (e.g., 18.5 reads reasonably well)
- Track 18 shows as “needs adjustment”, while 18.5 is readable
The attachment 2026-04-30 20.32.52.jpg is no longer available
The attachment 2026-04-30 20.32.33.jpg is no longer available
It really looks like the head is shifted by half a step.
Electronics (main board) are definitely OK — I tested it in another known-good drive.
So this seems to be a mechanical issue. However:
* I aligned track 0 using a diagnostic tool, and it reports “perfect”
* I tried adjusting by slightly loosening the stepper motor screws — almost no effect
* The best I could achieve was changing the message from “NEAR HALF TRACK” to “HALF TRACK”
But I simply cannot shift the head enough for it to properly read full tracks.
At this point I’m stuck. Has anyone seen similar behavior or has ideas what else I could try?
Thanks in advance.
Reply 1 of 1, by wierd_w
Clean and reoil the stepper?
Verify the resistance values of any driving circuit resistors? (Verify with a logic probe / scope that only the correct number of pulses are happening on actuation?
Rationale:
if track 0 is correct, but it is drifting off the correct track positions as the head moves, then either it is not actuating correctly (dirty,stiff mechanism), or is actuating too much (too nany pulses per cycle).
