First post, by legodude
So like any good tale of woe, it all started one day when I was browsing Ebay for Fore ATM gear and I noticed something interesting in a "system controller" for a large ATM switch:
The attachment 2026-04-12 11.47.45.jpg is no longer available
I convinced myself that I had to have it and after some back and forth, I ended up having the board shipped to my house where I quickly liberated the real prize:
The attachment 2026-04-12 11.48.17.jpg is no longer available
This is a Ziatech/Ribbon/Performance Technologies 5520 - compactpci 440FX dual pentium pro board. On the bottom of the board you can see a network mezzanine card, hiding under that is a compact flash board.
Datasheet is available here: https://web.archive.org/web/19970626050439/ht … heet/5520ds.pdf
I was also able to find a copy of the manual:
The attachment ZT_5520_Manual.anothercopy.pdf is no longer available
While the datasheet shows a VGA port, I don't believe the board has any video function without a special VGA mezzanine module (zPM10 or zPM11). I put the board in a chassis and hooked up the serial port and was greeted with angry VXWorks - it complains that it can't find some necessary hardware and then bootloops, which makes sense. There was no BIOS output over the serial port. Pulling the CF card just makes the bootloader angrier:
The attachment bootloader.png is no longer available
I imaged the CF card but it is just a VXWorks install. I tried a compactPCI video card, however there is no output (even with keyboard connected). There is a worrisome label on the board:
The attachment 2026-05-04 22.40.39.jpg is no longer available
As a last ditch, I blew away the flash card and installed dos on it with ctty com1 in autoexec.bat, however the boot loader does not want to boot from a dos partition.
Reply 1 of 3, by legodude
Continued...
I can interact with the boot prom:
The attachment bootprom options.png is no longer available
My goal is to liberate this board from the clutches of VXWorks. Unfortunately, I cannot find the bios anywhere. The bios/prom is located in a TSOP chip and I'd love to dump what is on there, at least as a starting point. I have a strong preference to not desolder the flash chips, but I will if I have to.
There is a 32pin "BIOS recovery socket" which can be populated with an EEPROM and then booted (see manual pg 74). Any suggestions for a bios image to try in here? This seems to be a pretty low risk way to try out ways to rescue this machine.
Reply 2 of 3, by luckybob
https://www.ebay.com/itm/327117822606
I thought this overpriced board looked familiar
Reply 3 of 3, by legodude
$70 shipped so much less than that auction 😀
Luckybob and I did some chatting on discord and my next step will be to try the BIOS from one of Intel's 440FX boards and see where that gets me
