First post, by BitWrangler
- l33t++
Hi Vogons,
The Trident 3DImage line has recently become of interest to me, due to learning that they have a triangle setup engine. Now like many 3D parts of the late 90s, they might have been a year behind when they would have been top class. These for example might have provided performance equivalent to software rendering on a PII-266 ... trouble is, ppl who were buying, were looking for something to make their machine faster at 3D, not be the same as putting a 2D card in it, because they were already buying a CPU that fast.
So I am thinking along the lines of "What if?" you had a slower machine, PCI only, and wanted to double it's speed at 3D, buying a card you hoped you could buy maybe a year earlier, but came out too late.
Thus I come to look at the 3DImage, the 9750 being the founder model, and available in PCI, but of course I wonder about the improved/fixed 9850... I am seeing absence of PCIs "around" and no mentions, but also I found a PCI device table where a device ID was allocated for a 9850 PCI... so wondering if there WAS one manufacturer who trotted one out, they just being obscure rather than non-existent.
Also I notice the SiS6326 has full triangle setup and may bear investigation. Again it's a case of it coming on the market at the time where it's acceleration was outpaced by the fastest CPUs, so gaining a "decelerator" moniker like others, but if it "does nothing" for a 300Mhz CPU, that doesn't mean it does nothing for a much slower CPU, providing drivers are not too heavy.
Heaviness of drivers is why I think I won't be thinking about RagePro/XL as they were demanding PII as minimum spec at launch. So seem like they are CPU demanding, more so than others... even though they are supposed to also have full triangle setup.
So anyway, don't know whether to "camp" for sale listings in case a 9850 PCI eventually shows or whether to settle for a 9750 earlier... or switch attentions to another card... hard to find CPU scaling info for old cards, and even find your way through the BS to what cards actually unload from the CPU and whether other features that are shovelwared into the driver will negate all unloading by giving the CPU too much else to do instead.
