First post, by renejr902
Hi everyone. I used the Toshiba 400cdt panel lcd with his vga cable and put them in a Toshiba 430CDT. For first time i can play need foe speed se and duke nukem3d in dos in 640 x 480 resolution and its playable. No stretching, perfect pixel resolution. So cool. I did success with a 420cdt with the same job but the 430cdt is faster. It's the fastest laptop in the world with a 640 x 480 native resolution, screen lcd panel. Check the picture. Check my frankeinlaptop 😁
Reply 1 of 6, by renejr902
The laptop close great and solid. But i took the 400cdt screen layout and lcd panel plastic, so it's a little shorter than lcd 430cdt lacd panel plastic layout. I exchange the speaker too and solder cables, because the original speaker was busted and the plastic melt in the connector. I made the soldering, it's not good as my father, dont judge me 🤣, but it's still good
Reply 2 of 6, by butjer1010
If You want great sound too, buy opl3lpt from Serdashop!!! You need to hear that sound on laptops!!! I did it with old Commodore 386 laptop, and i was delighted 😉
Reply 3 of 6, by renejr902
butjer1010 wrote on Yesterday, 07:32:
this laptop has already a ess688 sb compatible with a real chip yamaha opl3 262
Reply 4 of 6, by butjer1010
renejr902 wrote on Yesterday, 09:55:
Woow, didn't know that!
Than it's ready to R'N'R 😀
Reply 5 of 6, by RetroPCCupboard
I have a 480CDT (233Mhz MMX) and several 460CDT (166MMX). I wonder if I could put a 640x480 screen in these....
Reply 6 of 6, by RetroPCCupboard
This laptop also supports a gameport through it's dock also. I think the actual gameport controller is in the laptop and the dock is just giving access to it. So I have considered trying to add a gameport to the laptop itselfby soldering to the pads that lead to the dock port..
