First post, by mr.spencer
Hello everyone,
This is my first post.
I wanted to share a PC/XT motherboard I designed, based on the IBM 5160 and influenced by the many Taiwanese turbo clones of the era. I called it the DubaiXTClone.
The main differences from a standard XT design: 8MHz turbo with runtime speed switching, static RAM (no refresh), reduced IC count, 4-layer PCB, and real-time bus activity LEDs driven by otherwise unused gate outputs.
Fully open hardware under CERN-OHL-W v2 — schematics, PCB and PAL source code all included.
Tested with JUKO 2.31, Turbo BIOS 3.1 and others. SVGA Trident, 3COM, RTC, Floppy, and XTIDE all confirmed working in turbo mode.
As a side note, it also runs LMChat (https://github.com/spencer-uk/LMChat), a chat client that connects the board to a local LLM via LMStudio.ai application - ELKS and MS-DOS, both are supported.
GitHub: https://github.com/spencer-uk/DubaiXTClone/
(in the picture: top board DubaiXTClone, bottom IBM5160 - for comparison)
Happy to answer any questions.
~Spencer
