First post, by RedSarg99
Hi all. Search hasn't been kind to me.
I have a SB Audigy 1 and 2, and managed to nab a XIFI front panel, it looks exactly like the Audigy platinum IO panel just missing the 1394 ports.
Would a standard IDE 40 pin cable suffice to hook it onto the audigy card?
Reply 1 of 5, by ott
RedSarg99 wrote on 2026-05-13, 08:05:
Yes, I can confirm that this cable will work with Audigy2/2ZS and X-Fi I/O Drive panel (SB0251).
As for Audigy1, it's not compatible with Audigy2/2ZS/X-Fi panels due to the difference in pinouts:
Re: Different versions of Live Drive?
Reply 2 of 5, by RedSarg99
ott wrote on 2026-05-13, 09:41:
Yes, I can confirm that this cable will work with Audigy2/2ZS and X-Fi I/O Drive panel (SB0251). […]
Thanks
I'll double check which card is in my w98 PC build.
Reply 3 of 5, by ott
Don't forget to check the 1 pin on IDE ribbon cable (red stripe), it should match on both devices (1st pin marked with heart symbol)
Reply 4 of 5, by RedSarg99
ott wrote on 2026-05-13, 10:41:
Annoyingly my audigy 2 card is for the ex variant and hasn't got the header.
We are sure the pin layout for audigy 1 and the xfi panel are not directly compatible? (Here's hoping)
Reply 5 of 5, by ott
RedSarg99 wrote on 2026-05-13, 15:44:
Since X-Fi panel (SB0251) is identical to Audigy2/2ZS panel (SB0250) except for the missing Firewire, this has already been discussed in the same thread:
You can use SB0251 panel as headphone DAC with Audigy1, but you'll need to make your own cable, as the pin layout is different.
https://polprog.net/blog/audigy2zs/
