holoprox wrote on 2026-05-23, 09:42:
when i see EXACT same transistors on 4 different boards from this era
thats what jelly bean means 😀 just like you will see LM339 or NE555 in everything. What I meant is you dont need to use _those exact transistors_ because original designer didnt really pick them specifically.
but the diag board complained about the reset circuit!
as was my first guess, most likely arranged as monostable multivibrator https://www.tutorialspoint.com/pulse_circuits … ltivibrator.htm Circuit that generates a pulse of fixed guaranteed width (important in case of Reset) on input pulse of varied width + will also generate said pulse on power up automagically as a side effect of its design.
TLDR: you can use any two random ordinary PNP/NPN transistors, for example seeing you are from EU you can slap BC547 (NPN) and BC557 (PNP) in there no problem.
