First post, by limsolo
- Newbie
Hi All,
OK so dead FW82371 southbridge, injecting 3.3 volts at 1500Ma into the 2SK2941 3.3v MOFET (corner near DIMM slots) source under thermal camera it (southbridge) hits 80 degrees after around 10 seconds. Not sure how or why this happened. Here is the story.
Board working fine, swapped out the ICS 9150 for a 9250 board working fine, still could not O/C my dual PIII Slot 1 850's though, all I wanted was 112MHz bus which it would not do with the 9150 (bug) so still would not do it with the 9250, so was looking at a way to up the CPU voltage around 0.1 volts and see if that would do it, anyway board is on the bench and I am reading a datasheet on my lab PC, Windows 2000 blue screens and then the board is dead, no life at all, I check all powers and ground at ATX connector all good, so anyway I find primary CPU is dead/cold but secondary CPU is getting warm, so I check and the MOFETS for second CPU giving correct voltage but primary nothing zero, so I swap CPU's, cold CPU that was in primary in second slot gets warm. So I check HIP 6019 and nothing conclusive so I fit a new one - no change still not power to primary CPU. I should also mention CPU fans do not run.
So PC Analyzer card in ISA and PCI no 3.3v rail so find the 3.3v MOSFET as mentioned above, source nothing coming out but 5v going in the drain, and gate is getting around 2.6v not high enough but not dead either, so lots and lots of checking, scope the 9250 and that is giving PCI clocks 33MHz, 24 and 48MHz clocks (I thought maybe the new 9250 was shorting and pulling down the 3.3v rail) but it looks like its alive from the scope.
So I then start to inject 3.3v into the source leg of the 3.3v MOSFET with a bench PSU, first 200Ma, then 300Ma at around 600 Ma the CPU fans start to run, at all the time I am looking at the board with a thermal camera, nothing odd, room is 25C and it this point the hot spot is the Piezo speaker at around 30C (???) so then I get up to around 1200Ma, still nothing hot and at this point I get a two tone error from the Piezo which repeats low > high > low > high and cycles like that (and I cannot find any info on what this error is) so anyway just got to 1500Ma (still set at 3.3v) DMM meantime the source pin is showing 2.9v so 0.4 volt drop because of the load but at this point the alarm went off on the thermal camera. at 1500Ma and 3.3 set 2.9 actual it was pulling nearly 5 watts.
So shorted southbridge pulling the 3.3v rail down, I think I will just for the sake of it remove the southbridge just to make sure the short is gone, logically it should be. I should also point out at this stage, all my soldering work is fine, checked under a 4k camera/scope and DMM all over the place before hitting the board with voltage injecting showed no shorts to ground or low resistance anywhere so all basics covered, also in this state doing injection, no PCI or ISA cards, no drives, no ram, no CPU's or fans fitted, just the bare bones board plugged into an ATX supply (on) and the bench PSU supplying the 3.3v rail manually.
So question is had anybody seen a P2B-D or (DS) or even a P2B or another make/model of 440BX board die all of the sudden because of a fried southbridge?
Thank you
NeXTCube Turbo - Dimension, NeXTStation Turbo Color, SGI Octane R12k x2 MXE Impact, Dell Precision 7560, MacBook Pro Retina 2015, Macintosh Plus, Macintosh Quadra 840av, Macintosh Quadra 650, Wallstreet 500 (G4), Pismo 550 (G4).
