Guess the Specs!
First post, by CharlieFoxtrot
I just picked up this desktop system which I'm pretty confident is a new old stock clone from early 90s. It came in the original case cardboard box with styrofoam inserts and the case is like a new with ZERO scratches and scuffs. This is pretty likely surplus stuff that got forgotten to the back corner of a shop storage room or something like that. Pretty neat.
The attachment Front.jpg is no longer available
The attachment Back.jpg is no longer available
Morse was a pretty popular line of clones back in the day, there were at least couple of stores that used the name (can't tell if the shop just changed the name at some point or there were actually two different stores) and there actually still exists one local store that uses Morse brand for their pre-built computers.
Let's cut the crap and get to the business. I don't know anything about this system except that it is a Morse clone with most likely some kind of 386 CPU. That's it. I bought this completely blindly and seller, a recycling store, didn't provide that much information either. I have zero clue what actually is inside of this thing. The front badge has gotten bad due to age, but it just reads "Morse 386". It has one sticker on the right side which just shows the model name (like Morse type 386slp or something like that, didn't look that closely) and the sticker also has PSU specs. Nothing else. Nada.
So it is time you my fellow enthusiasts to tell me what I will find inside. Is it 386DX or is the badge a bit scammy and it just has a lame 386SX? And what kind of CPU oomph, that is MHz numbers we are dealing with here? What kind of a mobo we have and how about RAM? And HDD? Do we find some slow ass Oak or Trident graphics card inside or did I get lucky and get something like ET4000?
And how about some other stuff? Is there massive battery damage or again, did I get lucky? How about the age of the system, what kind of date codes we will find that will at least help to figure out the year when this computer DIDN'T get sold for some reason? And maybe some other stuff, go a head and figure this out!
I will post pics from the inside when I actually have time to fiddle with this, perhaps next weekend or so. In the meantime, floor is yours. The guy or gal that I feel really has some otherwordly superpowers will have the right to use "Nostradamus of the Retro Computing" title in their sig.
Reply 1 of 9, by BitWrangler
I reckon it might have one of those 386/486 boards, with VLB, soldered down AMD DX40, empty 486 socket.
Reply 2 of 9, by keenmaster486
Ooh, awesome. I have a 286 in that exact case.
I would guess you're going to end up with a 386SX-16, but I suppose it could be a DX, or even a later 486 era cheap 386, like a DX40.
Those ports on the back: the left one is a multi I/O card, with integrated gameport and parallel port, and the two male D-subs are not a card, but breakouts for the two serial connectors on that card.
It's obviously an AT motherboard, given the keyboard connector.
The 3.5 inch floppy drive in the 5.25 inch bay instead of its dedicated 3.5 inch bay that's right there for the taking could indicate that there is a 3.5 inch hard drive taking up the floppy bay, and there is thus an IDE card in the system, or perhaps it is indeed a later 386 or 486 motherboard with integrated IDE - but in that case it wouldn't make sense to have the multi-IO card, as the IO would also probably be integrated into such a motherboard.
And now that I look at it, there are no portless ISA cards in the system. Every other slot is taken up with an indented bracket that could not be a card.
Based on that I think the multi-IO card has IDE on it as well, and there is probably an IDE HDD in the 3.5 inch bay.
In fact, I think you will find a chip labeled "M5105" on that board!
The VGA card lacks DIP switches, so it's probably a later one. Oak or something. That might lend weight to either the 386SX or the cheap 486 era board theories, as this could have been a 386SX system that originally had an EGA card and was upgraded to VGA.
World's foremost 486 enjoyer.
Reply 3 of 9, by BitWrangler
I should complete my guess I guess.. so 120MB Seagate ATA, 4x1MB SIMMs, Trident 9440 VLB VGA with 1MB.
Reply 4 of 9, by st31276a
My guess is it’s a 386SX-16 with 2MB, a 256k VGA (maybe a TVGA9000c) and a 40-ish MB IDE like a CP3000 or a ST157A. Battery leaked.
Reply 5 of 9, by the3dfxdude
Seems very office and budget level. I'd say it's a late 386 era system (can be IBM/Cyrix 486 or just "386"). Around this time, most likely 386DX-ish. It could have an unusually low amount RAM (under 4MB) if it really was never opened to put to use and not going to be more than 4MB. As a 386 class, it likely doesn't have VLB. The only hope is that the VGA card being placed far down the slots where VLB is might mean it does have VLB, but it also could just be where there is enough room for a longer ISA card. 512KB Trident SVGA is my guess being a later era. 120MB IDE HD is a good guess too. Hopefully it still boots...
Reply 6 of 9, by mkarcher
The fact that other people reported having a 286 system in the same case and that the model name might be "386slp" including the letter "S" as in "SX" and no clock speed indication makes me join the 386SX-16 camp. Further guessed specs: 2MB RAM, 40MB hard drive, low-end VGA, possibly Paradise PVGA1 or OAK 037C. Might be 512K, but might also be just 256K. I guess the system is too old for a Trident 9000, so a cheap Trident would be the ancient Trident 8800 (that's not a typo for 8900, but the previous generation).
The mainboard is likely going to have a 286/386sx chipset like the C&T SCAT ("single-chip AT") or the VLSI TOPCAT chipset.
Reply 7 of 9, by dionb
Nice box 😀
The VGA card is the best hint. If this had been an early 386, it would have had a 9p digital output as well. No sign of that, which suggests this is a late 386 from the time when they were low-end. The 3x 5.25" and vertical 3.5" also points in that direction. So I'd say Am386DX-40. Pair that with a low-cost small baby-AT motherboard with single-chip chipset. 16b ISA multi-I/O card (with the extension bracket for 2x serial from a different card...) and VGA... something low-end. Oak or Trident probably, although C&T or UMC might also be options. 4x 1MB 30p SIMMs.
Reply 8 of 9, by Aui
Great Find !
This case actually already featured in an earlier thread about the "quintessential AT case":
Newly made Retro styled AT/Baby AT Case
Incidentally, I recently found a machine in exactly the same case. However, unlike your find my one was a maxed out and someone took it to the very end of the AT era with a Pentium MMX / DVD drive etc.
My guess is "AMD 386 DX40"
Reply 9 of 9, by BitWrangler
Aui wrote on 42 minutes ago:
The very very end is more like PIII-S 1.4 ghz in an AT BX board.
