First post, by CrashGalore
A few weeks ago I picked up a new project. Just for those in between other projects. I paid a few eurobucks, nothing crazy, because it was dead. And dead it was...
PSU broken, MFA Disk broken, 2 barely functioning Floppy Drives, a bunch of broken memory ic's, exploded battery and a broken I/O card because of that. It has been a strugle.
But progress, and I wanted to share.... finally. Recapped and also replaced the psu. Cleaned up the floppy drives, replaced most of the memory. Plugged in another I/O card, Diskdrives don't get recognized by the original, even with a new battery. also been strugling with the manual and its errors.
She is starting to breath again. I am so happy. Hence this share.
Reply 1 of 5, by BitWrangler
Aw yiss.. now for one of my somewhat tangentially related references "Vtech kicked in yo!" 🤣
Reply 2 of 5, by Horun
Good work !
Reply 3 of 5, by CrashGalore
BitWrangler wrote on 2026-05-21, 00:48:
It's true, what I thought was a fun side project, almost became a big sore in the...
Reply 4 of 5, by CrashGalore
"You gotta love sthe sight of traces in the morning..."
Reply 5 of 5, by CrashGalore
Update:
Yesterday the parts arrived for a HIDman AXP keyboard converter. Finally I should be able to have some input. This is comming together.
Is it original? No, far from it...
Is it period correct? Please refer to the answer above...
Does it have a big red switch? Oh yeah!!, a small one also, for that matter!!
Is it working? H*ll yeah!!!
Is it purrfect? Nope
Is it finished? Probably never...
Is it budget build? Yes? No? Probably...
Need:
RTC + Battery. Aftermarket DIY. Since the original IO card is dead. Despite diagnose / repair attempts. The Zilog Z0765A08PSC doesn't receive a clock signal.
Greed:
8087-1 fpu cpu. Just to fill that empty socket.
OCD trigger:
The hideous tricolor front due to the TEAC 1,44 floppy drive, must ..do ..something ..about that.. soon
Specs:
8086-1 Intel 10 MHZ
640K conventional + parity
1024K expanded + parity
VTECH MDA/CGA Graphics adapter (512K?)
3com Etherlink 8 bit NIC
XT IDE IO Card + Universal BIOS
PT1227W I/O card
Maxtor IDE spinning disk, to many GB's20K D
Chinon 5 1/4 DS/DD fdisk drive
TEAC 3,5 inch 1,44 fdisk drive, the original Chinon 7 Disk drive seems to be working erratic. I think that might be because I use HD 1,44mb disks, formatted as 720K. The 1,44 drive is reading and writing the 720K formatted 1,44disks flawless.
HIDman AXP XT/PS2 keyboard converter
MS-DOS 6.22 Dutch
Pics:
