First post, by JTilla
JTilla
Offline
I have an MT32-Pi set up which I use for many games with my original pc with an Ess Solo1 sound card.
I've run out of ideas to get the General Midi working on this game. I have it set in the config to use the GenMidi.drv on the correct port
SoftMpu gets correctly loaded with the soundfont mode set in the mt32pi config (This works fine in Tie fighter and Monkey Island)
I use midito.com vR12 to lock auxB and check the volume is correct in Essvol as I know the issue of the mixer values getting reset.
Im using the original CD version from the Sierra Originals line RCV 10000161
When I play the game I get title music and FX from the Sound Blaster but nothing in Midi. I don't know what else I can check or try?
