Disruptor wrote on 2026-05-26, 04:48:
rmay635703 wrote on 2026-05-26, 01:22:
Disruptor wrote on 2026-05-25, 22:26:
My AMD-K6-2/333AFR 2.2V CORE/3.3 V I/O A 9830EPAW doesn't even run stable at 350 MHz.
Reminds me of the older 300/66 k6 chips that became unstable on 100mhz FSB and required the strange 3.52 VIO despite the 2.2 vcore
My AMD-K6/300AFR 2.2V CORE/3.45V I/O A 9827BPHW runs stable at 3x100 MHz.
Is it marked 66mhz only?
The attachment IMG_8855.jpeg is no longer available
There was a period of time where certain chips were marked 100mhz FSB and others were marked with a different model number that indicated a 66mhz FSB limit
The earlier 66mhz chips that existed before pc100 was common don’t count.
BitWrangler wrote on 2026-05-24, 21:46:
In general, all CXT K6-2s seem to manage 50mhz. Best overclockers are lowest core volts, highest heat range. Beware of very early non-CXT 400s which were basically rare freaks to manage 400 at all before the CXT changes. They are going to be mid 98 date codes though, the plain jane chompers.
Oddly there were somewhat rare earlyish 2.4 volt 475mhz rated parts.
Those must have been some real dogs releasing before faster 2.2 volt chips were common.
Bringing me down memory lane with all the god aweful strange k6-2 clockings, there was a 466mhz rated chip, strange FSB.
Oddballs like 366, 380, 433, 475, 533, 570 never made much sense
