First post, by BuckyWootmaster
I'm trying to recover an Arcom SBC-GX1-M0-F16 controller from an industrial sheet metal machine. The BIOS chip (Macronix MX29F002NT) is confirmed erased via a XGecu T48 programmer. The SBC-GX1 runs Windows CE 3.
Does anyone have any info on how to find a BIOS image for it? I've searched the retroweb and they have a listing for the board but no BIOS. I just need to get the board to boot up enough to dump the on-board flash data.
I'm looking into purchasing donor boards to pull the BIOS from if it's not in a database somewhere.
I appreciate any help or info.
Reply 1 of 3, by Thermalwrong
BuckyWootmaster wrote on 2026-05-28, 15:46:
I'm trying to recover an Arcom SBC-GX1-M0-F16 controller from an industrial sheet metal machine. The BIOS chip (Macronix MX29F00 […]
Try this, just backed up the one from my SBC-GX1-M64-F16. I've had it in this fancy devkit box for a few years now.
Seeing that your one's BIOS flash chip has lost its data and that I didn't have the BIOS archived but everything else in the devkit box was, the BIOS is backed up now.
Mine uses a Macronix MX29F002TQC-70 chip and the label on top says Award D586 BIOS PHOENIX 1998
Hope that helps you get the onboard flash memory backed up 😀
Reply 2 of 3, by BuckyWootmaster
Dude thank you so much! My only worry is if somehow since it's a slightly different variant of the board it might wipe the on-board flash memory. That's like a 1 in a million chance so, if I can't get this thing running soon I'll definitely try this BIOS.
It's awesome that you were able to get that so quick!
Reply 3 of 3, by Thermalwrong
BuckyWootmaster wrote on 2026-05-28, 23:50:
It shouldn't, that's just the RAM configuration that's different between the two and the flash config on both our boards matches up 😀
Though I've packed it away again now, from what I can tell the memory configuration is just a user replaceable SODIMM.
Glad I can help 😀 I didn't realise the BIOS was both not backed up and not available online at all.
