First post, by M95D
Hi.
I need help. My old sound card died.
It's a no-name OPL3SA3 with Yamaha YMF719E-S. The card is detected, FM works, but wave playback isn't working. When I try to play something in DOS, the game freezes. In Windows, it doesn't freeze, but the player is "stuck" at the beginning. The playback timer and cursor do not move.
Do you think it's repairable?
I did soldering before, replacing caps or other minor repair (on other boards, not this one), but I'm unable to diagnose the problem. I see no obvious problems such as bad caps or burn marks. I was thinking that maybe the oscillator died? I have an oscilloscope but it doesn't go that high.
Thanks.
